Can't Open control panel
ok, repairing windows did not work. i still have the problem
    Gateway GM5632e
    3gb
    8500GT
    7.1 one. idk the actual name for it
    one 22" moniter
    1680 x 1050
    2x 500gb
    5 up, 20 down
At this point damastah, you could just do an install over your current one, then restore your files and settings.
~Lordbob
    ASUS P5QC
    2x2GB
    NVidia GeForce 9500GT 1Gb
    Mobo
    Samsung SyncMaster 206bw
    Samsung SP2514N ATA 250Gb 7200RPM
    Samsung [Model] 1Tb 7200RPM SATA2
    Razer Tarantula
    Razer Lachesis
    not fast enough
~Lordbob
how would i restore my files and settings?
thanks
    Gateway GM5632e
    3gb
    8500GT
    one 22" moniter
    1680 x 1050
    2x 500gb
    5 up, 20 down
~Lordbob
thanks
That way is rather difficult. You can check out my tutorial: http://www.vistax64.com/tutorials/237033-windows-old-folder-restore-into-new-installation.html
Make sure you are comfortable editing from Command Prompt, and are willing to take the risk of naming a file incorrectly and causing problems
Any rename problem should be able to be fixed, but I recommend not making them.
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Tarantula
    Razer Lachesis
    not fast enough
Alright, I suspected as much. Shut down the computer, and boot into your Vista Install Disk. Instead of choosing Install, select Repair Your Computer.
Find your installation, and try a repair install.
~Lordbob
bob, i clicked on repair. but it didnt do anything. it gave me 4 options, one was startup repair, one was system restore, one was system complete restore, and another was memory scan something(i dont remember what it was, but it started with memory) and the last was Command prompt
i did startup repair assuming that was the repair you wanted me to do. did i chose the correct repair? or did i do something wrong. the link you gave me in the post above, its sooo long. but i want to use that as a last resort, because it will take an hour or two, and i dont have a printer
thanks
    Gateway GM5632e
    3gb
    8500GT
    one 22" moniter
    1680 x 1050
    2x 500gb
    5 up, 20 down
~Lordbob
thanks
That is the right one, but in my experience, it does not work well.
I gave you the tutorial to use if you just want to try a clean install. It actually only takes about 15 minutes, and is fairly simple. I could guide you through it if you need it.
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Tarantula
    Razer Lachesis
    not fast enough
~Lordbob
thanks
~Lordbob
guide me as in through the phone?
because i can use the guidance. ;P
    Gateway GM5632e
    3gb
    8500GT
    one 22" moniter
    1680 x 1050
    2x 500gb
    5 up, 20 down
i cant open Network and Sharing Center either. when i open it i get this message, "Windows Explorer has stopped working. " then that message changes to "Windows Explorer is restarting." help please !!!
thanks
Why dont u give a try of this before going to reformat,
  1. this, right click and empty area on your desktop, point to New, click Folder, and then type cpl.
  2. Move all of the .cpl files out of the System32 folder and into the cpl folder that you created.
  3. Verify that Control Panel opens. Note that Control Panel does not contain icons after you move all of the .cpl files out of the System32 folder.
  4. Move the .cpl files back into the System32 folder, one at a time, and then open Control Panel after you move each file to verify that Control Panel opens.
  5. If you move a .cpl file back into the System32 folder, and Control Panel does not open, delete the file, or replace the file with a known, good .cpl file.
let me know the result :)
    Wipro
    Intel dq35j0
    8 Gb
    inter express chipset
    Realtek
    Wipro
    1024*768
    500 gb
    DELL
    Dell
    100 mbps(office lan)
thanks
~Lordbob
That was not what I was thinking, but if you really need to, I could.
If you have a second computer, just open up the tutorial on the good one, then follow it. It is fairly simple, just follow the directions.
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Tarantula
    Razer Lachesis
    not fast enough
thanks
i need permission to move these .cpl files out of system32. i could only move 5 of them out, there was 50 left?
    Gateway GM5632e
    3gb
    8500GT
    one 22" moniter
    1680 x 1050
    2x 500gb
    5 up, 20 down
i had UAC off, and i thought the permission thing was becaus of that right? so i turn UAC on, and i have to restart the computer. i see i have an update for my computer, so instead of clicking restart, i clicked the red button that inststalls update then restarts it. it would not restart correctly. it would show everthing up until the loading screen where the green bar goes left to right. then after it "loads" screen goes black. and stays black. i used the CD to repair it, i clicked restore, i clicked on last night after i uninstalled the antivirus. and it restored, i booted it. it had the same problem. so i turned it off, and booted it from the CD. then i did startup repair, it said i have something plugged in like a camera or something like that. so i took out my SD card and this one USB that wasnt connected to anything at the moment, and i rebooted it, started from the CD and clicked startup repair, got the same message. it said if this message pops up i should contact my administrator. my computer sucks. :'( first control panel, now it wont turn on. :'(
EDIT
it works now. it just took like an hour for that black screen to show my login area
    Gateway GM5632e
    3gb
    8500GT
    one 22" moniter
    1680 x 1050
    2x 500gb
    5 up, 20 down
How do you restore windows.old
I am getting this error;
C:\windows\system32\explorerFrame.dll is either not designed to run on windows or corrupted. I have done the scans, ran reg cure etc. It says they found a problem but cannot fix it. I cannot open anything, control panel, docs, photos, nothing. If I install over it says it will erase but If you say do not format I can retrieve my docs?
Thanks in Advance
Kim
Thanks in Advance
Kim
kim i think this is what you are looking for?
~Lordbob
thanks
~Lordbob
***EDIT***
dont thank me. thank bobbio
    Gateway GM5632e
    3gb
    8500GT
    one 22" moniter
    1680 x 1050
    2x 500gb
    5 up, 20 down
OMG IT WORKS!!!
the five files that i moved out of my system32 folder made it work again!! haha. im just gonna keep those files there. i have no idea y. ill let you guys kno if this problem persists THANK YOU EVERYONE WHO HELPED ME!
bob the most kuzz i could tell he was getting a little frustrated. thank you!
    Gateway GM5632e
    3gb
    8500GT
    one 22" moniter
    1680 x 1050
    2x 500gb
    5 up, 20 down
OMG IT WORKS!!!
LOL Glad you got it figured out.
I was only frustrated because I ran out of ideas.....
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Tarantula
    Razer Lachesis
    not fast enough
OMG IT WORKS!!!
~Lordbob
HAHA ok, thanks bro. i cant rep you again. :'( but i think ill soon be back. but it works for now. let me check again
edit
yup still works
thanks again man
    Gateway GM5632e
    3gb
    8500GT
    one 22" moniter
    1680 x 1050
    2x 500gb
    5 up, 20 down
thanks
Glad it worked for u ....
    Wipro
    Intel dq35j0
    8 Gb
    Realtek
    Wipro
    1024*768
    500 gb
    DELL
    Dell
