uptoeleven
completely hosed? Vista booting problems
It's not often I admit defeat but this one has got me. A friend came to me with her laptop, Vista wouldn't start. The usual "maybe it has a virus?"
The machine is a DELL XPS M1530 - T9300 core2duo, 4GB RAM with a screen to die for - 1920x1200 on a 15.4" chassis. I'm jealous...
So here's the symptoms and where I'm at so far. Plug in power, switch on, POST runs, tells me it's a DELL F2 for Setup F12 for boot options (diagnostics are in there) blah blah blah. When that is done, goes immediately to black screen with tiny white flashing line in top left and that's it. BIOS Diagnostics say all is well. No boot options of any kind - it looks like we've lost the HD boot sector at the very least.
Removed HD, plugged it into my tower, ran chkdsk, bad sectors so we went out and bought a replacement. Ran HDClone to copy the old drive (320MB) onto the new (500MB). chkdsk /B on the new disk doesn't find any bad sectors so we're good to go but it won't boot. Same black screen with white flashing cursor.
Recovery disk.
Vista startup repair from the Vista DVD runs successfully but rebooting gives a black screen with white flashing cursor.
bootrec /fixmbr
bootrec /fixboot
= black screen with white flashing cursor.
I've run back through with the startup repair from the install disk, nothing. Chkdsk'ed all the partitions (successfully) including the DELL MediaDirect thing that apparently can destroy boot sectors... set each partition active one by one in diskpart, it just won't do anything apart from the black screen. I can boot from a cd, I can boot from a USB stick... from the hard-drive it's black screen each time
So we're looking at a Vista reinstall
I log in using Ubuntu - everything is still there as it should be, it looks like a c: drive, all files are there, I'm just backing them up.
I have a couple of questions.
1.) Given that I can't get Vista to boot is there any way I can run a Vista "upgrade" install? I think that when the old hard drive went bad, what's missing is system files. Apparently it was complaining of missing dlls in the last few days. I reckon if I can find out which files are missing and drag them of the install dvd it will work... Running Vista install from boot media over-writes the whole OS, doesn't allow an upgrade installation. Is there sneaky work-around?
2.) Failing that - how do I back up settings and so on? Can I backup registry and other settings so that we can just bring them back when the machine is set up again?
This is turning into a ballache and any advice would be gratefully received.
Thanks
Recovery disk.
bootrec /fixmbr
bootrec /fixboot
Thanks
- Medion something or other
- i7 K2600
- MSI - 7728? something like that.
- 4GB
- Graphics Card(s)
- whatever's on the chip (for now)
- onboard + Alesis IO 26
- Samsung SyncMaster T240
- 1920x1200
- Agility 240 GB SSD
500GB thing it came with
1TB Seagate Barracuda. Various others
- 100MB
