Computer not responding
Copy and past the following into the custom scans/fixes box in OTL, then press run fix:
Code:
:OTL
IE - HKCU\..\URLSearchHook: {1E315374-71A5-471A-B683-4C4ADB5C588B} - Reg Error: Key error. File not found
O2 - BHO: (SMTTB2009 Class) - {FCBCCB87-9224-4B8D-B117-F56D924BEB18} - Reg Error: Value error. File not found
O3 - HKLM\..\Toolbar: (HyperCam Toolbar) - {338B4DFE-2E2C-4338-9E41-E176D497299E} - Reg Error: Value error. File not found
O13 - gopher Prefix: missing
O15 - HKCU\..Trusted Domains: 111222.cn ([list1] http in Trusted sites)
O15 - HKCU\..Trusted Domains: pps.tv ([kan] http in Trusted sites)
O15 - HKCU\..Trusted Domains: pps.tv ([list1] http in Trusted sites)
O15 - HKCU\..Trusted Domains: pps.tv ([tvguide] http in Trusted sites)
O15 - HKCU\..Trusted Domains: pps.tv ([vodguide] http in Trusted sites)
O15 - HKCU\..Trusted Domains: ppstream.com ([list1] http in Trusted sites)
O15 - HKCU\..Trusted Domains: ppstream.com ([notice] http in Trusted sites)
O15 - HKCU\..Trusted Domains: ppstream.com ([xml1] http in Trusted sites)
O15 - HKCU\..Trusted Domains: ppstream.com ([xml2] http in Trusted sites)
O15 - HKCU\..Trusted Domains: ppstream.com ([xml3] http in Trusted sites)
O15 - HKCU\..Trusted Domains: ppstream.net ([list1] http in Trusted sites)
O15 - HKCU\..Trusted Domains: ppstv.com ([list1] http in Trusted sites)
O15 - HKCU\..Trusted Domains: ppstv.net ([list1] http in Trusted sites)
O15 - HKCU\..Trusted Domains: security_PPStream.exe ([]about in Trusted sites)
O15 - HKCU\..Trusted Ranges: Range1 ([http] in Local intranet)
:Files
C:\Users\Alex Liu\AppData\Local\5tp0jtoe6u6hrfanp5a74iam6f2067y4l/D
C:\ProgramData\5tp0jtoe6u6hrfanp5a74iam6f2067y4l /D
C:\Windows\KMService.exe /D
ipconfig /flushdns /c
:Commands
[purity]
[resethosts]
[emptytemp]
[emptyflash]
[Reboot]
A log should open upon completion, I need the contents of this log AND a fresh OTL log please :)
Tom
P.S. Your KMService is now gone :party:
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    Samsung EVO 128GB SSD
    Seagate Barracuda 2TB 7200rpm
    NZXT Phantom 410
i tried opening OTL after running the fix, and this came up.
[EMPTYTEMP]
User: Alex Liu
->Temp folder emptied: 39953770 bytes
->Temporary Internet Files folder emptied: 394642 bytes
->Java cache emptied: 69288628 bytes
->FireFox cache emptied: 41785394 bytes
->Flash cache emptied: 1242 bytes
User: All Users
User: Default
->Temp folder emptied: 0 bytes
->Temporary Internet Files folder emptied: 33170 bytes
User: Default User
->Temporary Internet Files folder emptied: 0 bytes
User: Public
User: UpdatusUser
->Temporary Internet Files folder emptied: 32768 bytes
%systemdrive% .tmp files removed: 0 bytes
%systemroot% .tmp files removed: 0 bytes
%systemroot%\System32 .tmp files removed: 0 bytes
%systemroot%\System32\drivers .tmp files removed: 0 bytes
Windows Temp folder emptied: 2176609 bytes
RecycleBin emptied: 0 bytes
Total Files Cleaned = 147.00 mb
[EMPTYFLASH]
User: Alex Liu
->Flash cache emptied: 0 bytes
User: All Users
User: Default
User: Default User
User: Public
User: UpdatusUser
Total Flash Files Cleaned = 0.00 mb
OTL by OldTimer - Version 3.2.26.1 log created on 08032011_182906
Files\Folders moved on Reboot...
File\Folder C:\Users\Alex Liu\AppData\Local\Temp\OICE_E1E6FB77-5DC3-42CD-BDEC-720B81E522F2.0\9CE80093. not found!
Registry entries deleted on Reboot...
i will now try scan again.
    Compaq Presario
    AMD Phenom-64 8750 (2.4GHz)
    2814 MB ram
    NVIDIA Geforce 9400
    Generic PnP monitor
    1024 X 768
here you go
  • OTL.Txt
    Compaq Presario
    2814 MB ram
    NVIDIA Geforce 9400
    Generic PnP monitor
    1024 X 768
Copy and paste the following in to the OTL custom scans/fixes box and press Run Fix:
Code:
:OTL
O3 - HKCU\..\Toolbar\WebBrowser: (no name) - {338B4DFE-2E2C-4338-9E41-E176D497299E} - No CLSID value found.
O34 - HKLM BootExecute: (autocheck autochk *) -  File not found
:FILES
C:\Users\Alex Liu\AppData\Local\5tp0jtoe6u6hrfanp5a74iam6f2067y4l /D
A log will open upon completion, copy and paste its contents into your next post
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Code:
:OTL
:FILES
========== OTL ==========
Registry value HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser\\{338B4DFE-2E2C-4338-9E41-E176D497299E} deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{338B4DFE-2E2C-4338-9E41-E176D497299E}\ not found.
Registry value HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session manager\\BootExecute:autocheck autochk * deleted successfully.
========== FILES ==========
C:\Users\Alex Liu\AppData\Local\5tp0jtoe6u6hrfanp5a74iam6f2067y4l deleted successfully.
OTL by OldTimer - Version 3.2.26.1 log created on 08032011_185308
    Compaq Presario
    2814 MB ram
    NVIDIA Geforce 9400
    Generic PnP monitor
    1024 X 768
One last scan, just to make sure you're all good to go again:
Malwarebytes Anti-Malware
Download and install MBAM from here
Run a full scan and attach the log with your next post for me to analyse
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Can you do the same procedure for making the fix.bat, but this time I want you to do it with this text:
Code:
sc delete "Norton Internet Security"
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
ok, done the norton thing, now running the full scan, after, i'll get off safe mode and see if i can actually go on the computer without any problems
    Compaq Presario
    2814 MB ram
    NVIDIA Geforce 9400
    Generic PnP monitor
    1024 X 768
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
i cant uninstall programs in safe mode.. and it's still frozen when i load onto the desktop, i have to go now, so i may not reply for 1-3 hours, sorry about this. the log for malwarebytes was clean, i have no infected files, want me to attach it anyway?
    Compaq Presario
    2814 MB ram
    NVIDIA Geforce 9400
    Generic PnP monitor
    1024 X 768
Just remember to do it when we get you up and running again :)
That's fine, I understand that people have other time commitments
Nope, there's no point, you've told me all I need to know
Have you got a Vista installation DVD?
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
no, i don't think i was given a Vista installation CD when i purchased my computer, if i was, i must have lost it since i've looked everywhere, and can't find it :@
    Compaq Presario
    2814 MB ram
    NVIDIA Geforce 9400
    Generic PnP monitor
    1024 X 768
Okay, not to worry. Can you please explain any current problems that you have?
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Tom
ok, on my computer, when i start it up, when it gets to the vista welcome screen, it takes several seconds, maybe as long as 20 seconds to get to the desktop, whereas before it loaded in 1-3 seconds onto my desktop. Then my desktop is completely empty, with a black wallpaper, and then takes another few seconds to load my wallpaper and icons, e.g. My Computer, CCleaner.. Then when everything is loaded, the computer seems to freeze momentarily, where i can only press the vista button on the bottom left and open My Computer. trying to open the Mozilla Firefox doesn't work, and my internet connection has a red X on it, (on the bottom right of the screen) and well as nothing loading there. e.g. avast antivirus etc..., only my safely remove hardware thing is there, then thats it, my computer is frozen after a few minutes.
    Compaq Presario
    2814 MB ram
    NVIDIA Geforce 9400
    Generic PnP monitor
    1024 X 768
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
the first tip seemed to work... for now, i scan it tommorow.
    Compaq Presario
    2814 MB ram
    NVIDIA Geforce 9400
    Generic PnP monitor
    1024 X 768
Well in that case, thank you Rich :)
That's great news! What was the culprit?
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
