You should upgrade or use an
alternative browser .
I have Obituaries on my side bar. When I try to open one, it notes that the file does not have a program associated with it for performing this action. It tells me to create an association in the set association control panel.
I have gone into the tutorials, but I still don't understand.
Please HELP!!!!!!
Hello CountyGirl, and welcome to Vista Forums.
What is suppose to be opened when you try and open this file?
What
file extension does it have?
If this is a gadget that is suppose to open to a webpage, then double check to make sure that you have
Internet Explorer set as the
default program with all of it's associations set to it to see if that may help.
Operating System
1TB Samsung 990 PRO M.2,
4TB Samsung 990 PRO PRO M.2,
Galaxy S23 Plus phone
Operating System
