Solved Desktop Folder views not saving
CrucialHoax
Action is Knowledge
Hello all,
I have only one item on my desktop, which is a "Tools" folder, and every so often, the views reset to folders first, then apps, in alphabetical order. I've set the folder options to "Remember folder views" and it still doesn't save. It's not a big deal, just really annoying, because the way I organize everything is much easier to access, then randomly, windows resets the folder view...
Thanks in advance :)
Peace :)
    HP
    Intel Neo
    2GB
    Intergrated Intel Graphics
    Integrated
    160GB
    Power Adapter
    Acer
    Touchpad
    Down: 16mb/s Up: 1.6mb/s
    I killed my HP Laptop :'(
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
Hello CrucialHoax,
You can apply the download in METHOD TWO of the tutorial below to reset the folder view settings to have Vista remember the folder view settings of a folder window as they were when it was last closed.
http://www.vistax64.com/tutorials/70819-windows-explorer-folder-view-settings.html
Im in the process of doing that now, but when adding a new key named AllFolders under Bags, my Bags key has about 40 to 50 more keys underneath it... I have no clue what to do with them. Here is a screenshot explaining what I'm talking about, I'm still in the correct location, I just have more keys...
Mark :)
    HP
    Intel Neo
    2GB
    Integrated
    160GB
    Power Adapter
    Acer
    Touchpad
Mark,
I would recommend to use the download instead. It does all of the manual section automatically for you without having to worry about making a mistake.
Mark,
There wasn't a download, really there isn't even a "method three" or at least I couldn't find it, now with that applied, my folder view option "auto-arrange" is locked in the check marked position...
Mark :confused:
    HP
    Intel Neo
    2GB
    Integrated
    160GB
    Power Adapter
    Acer
    Touchpad
DOH!! Sorry, I meant under METHOD TWO. Posts edited above. :o
Don't fret over it, simple mistake. I deleted the keys I made like "AllFolders" since it was causing conflict. Never mind, even with it deleted I cannot uncheck the "Auto Arrange" setting...
I backed up my registry before I applied any of these changes, so I imported it back in and then started over, works fine for now :)
Thanks Brink
    HP
    Intel Neo
    2GB
    Integrated
    160GB
    Power Adapter
    Acer
    Touchpad
I'm happy to hear it is working for you now. :)
