Favorite Links - Hide
How to Hide Favorite Links in a Windows Explorer Window in Vista
This will show you how to hide or unhideFavorite Links inside the Navigation Pane in a Windows Explorer window. It contains shortcuts to the Documents, Pictures, Music, Recently Changed, Searches, and Public folders by default.
For more information see: Microsoft Help and Support: Article KB926167
The Favorite Links folder is located at: C:\Users\(your username)\Links
  • The Navigation Pane contains both the Favorite Links and Folders sections. You cannot turn off just one of these sections, only hide or adjust the size for one of them. If you turn off the Navigation Pane, you will turn off both of these sections as well.
  • If the Favorite Links section is empty, then see: How to Fix Favorite Links Empty in Vista Windows Explorer
1. Open a Windows Explorer window.​
2. Move your mouse pointer on the line between the Favorite Links and Folders sections until it turns into a double arrow. (see screenshot below)
3. Hold the left mouse button down, while the mouse pointer is a double arrow, and drag the section up to hide it. (see screenshot below)
NOTE: To unhide it just drag it back down.
Hi Brink
Thats kind of odd, and easy but I like it better.
I never would of thought of it.
Thanks :shock: Ted
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    HP Enhansed Multimedia
    Razer Diamondback 3G
    18.6Mb/s
    My First Build ;)
I do like it when they make it easy for a change. ;)
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
Re: Navigation Pane - Simple Folder View
Is there any Registry Hack to get rid of the Folders section while still keeping the NavPane? It keeps insisting on expanding when I open Computer. Just gets in the way.
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
