Hi skallz and welcome to the forums
This might sound like a daft question, but are you sure that the front panel is connected internally? There have been cases where it has not. Another thing - do your headset and microphone actually work? Check by using the sockets at the rear of your PC. You can check the front panel sockets (at least the one for audio out) by temporarily plugging your ordinary speakers in. Sorry that I can't help you any further other than with these suggestions, but if you require further assistance don't hesitate to ask. If you can reply with some more details, i.e. make and model of motherboard and also your soundcard (if it is not the on-board solution) then I will see what I can come up with for you.
Dwarf
