GPU-z confusing readout
fieseler
    §ĮŁΣNŦ Д$$Д$$ĮN
    Xeon X3360
    P5W64 WS Pro
    EVGA Geforce GTX470 SC+
    Samsung T200
    WD 1TB RE3
    Thermaltake Toughower 750w
    NZXT Lexa Silver
    Zalman CNPS10x Extreme
    Razer Lycosa Mirror
    Razer Deathadder 3500dpi
    24Mb/s
Regarding the memory don't forget that it is DDR (GDDR3 actually, but the same applies), which is double data rate, which in this case means that it is running at 2250 MHz.
As far as the 55 mm, 65 mm; does he have the latest version of GPU-Z? It could just be a reporting glitch if it is a version that came out before the card did.
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Acer P221w and Acer 1916w
    1680x1050 and 1440x900
    Antec Earthwatts 500W
    Antec Sonata III
    Logitech Wave
    Logitech G5 v2
It is possibly reading it wrong, check to make sure you have the most updated version of GPU-Z. and it's possible that you actually have a 65nm card. the QC isn't that great at the GPU plants. I got a GTX 260 with everything 260, sticker and all, but it was actually a 280 under the sticker.. but sadly it didn't work right and I had to return it. I've heard of people getting regular card and it's got the FTW Bios.. pre overclocked. I've heard of people getting the normal eVGA GTX 260. yet everything is stock, and the Core Clock is higher, but it's not as high as there lowest pre oc'd card. sometimes they just get messed with at the plants. but I'm not sure they even made the + version in 65nm.. let me check.
    Q9650 E0 4.0 GHz @1.304v
    eVGA 750i FTW
    eVGA/MSI GTX 260 SLI
    X-Fi XtremeGamer
    Samsung T240 & 226BW
    1920x1200 & 1680x1050
    PC P&C 750w Silencer PSU
    Logitech G11
    Logitech MX-518
in GPU-Z does it show it as a GTX+ cuz if I remember right, the + was the 55nm versions, and all the regular 9800GTX cards are 65nm, and the 55nm are the GTX+.
try updates first.
    eVGA 750i FTW
    X-Fi XtremeGamer
    Logitech G11
    Logitech MX-518
