ok before i start, i must admit; i suck with computers..
anyways
i wanted to play a LAN game with someone but it didnt work. i asked for help other places and they asked me if i was able to even share files using LAN..
and.. i just dont know how to get that done.
i have been looking at soo many posts and google links, but i still cant get it to work
this is what i have done and tried:
both firewalls are off, they are connected to a modem via LAN caples.
the second time i tried, my vista was also connected to the internet via a dial up modem.. i wanted to see if atleast i could get internet from my vista over to my xp but that didnt work.
anyways
on my Vista, in "Network and Sharing Center" the LAN network is there, and its called "unidentified network(public network)" and underneath it says Access: Local only Connection: Local area network.
on my XP, the LAN connection is also connected..
on the modem, their ports are lighting, so basicly they are connected to each other.
so now when i try to share a file from my vista over to my xp;
right click on file = Share.. = now here is the problem. i cant find anything to do with LAN. but it says that i should choose one of the users of the computer.. so maybe i cant choose the LAN? but i should be able to?
maybe its because i need to "create" a network where i can then configure it to use the LAN modem... but i dont know how to =(
on my XP.. when i go to my network places, i see alot of folders that i am sharing.. lol .. .. im so lost
however, long time ago someone already helped me share some stuff from my vista to xp. but i cant get in any contact with him and when he did it, he hardly explained it to me. i remember that he did alot of stuff on my vista.. so im guessing thats where the problem is.
i read some stuff aabout vista's "publicj folder" but all that i understood from mine, is that i can enable it to share between users on the vista.. and not to the other network.. if there even is LAN network?
im really sorry if i may sound negative, but i have tried for about 5 hours now.. (not in a row, with breaks ofcourse
help would be 10000x appriciated.
cos if i can get my file sharing to work, im one step closer in fixing my main problem lol..
thanks so much in advanced
ktadie
anyways
anyways
ktadie
