Help with Capturing Screen
I read that if you use Alt+Print screen that you can capture the active full screen and then paste into email if you like. I did this and when I went to paste it was greyed out.
Do you first have to go into paint... I tried both prnt screen and ALT+prnt screen.
Is there something I am missing
thanks, Ken
    Windows 10 Home
    HP 8312 (Socket FP4)
    Microsoft Optical Wheel Mouse
    62.86Mbps down 18.19Mbps up
thanks, Ken
Hello Ken,
Press PRNT SCRN
Open PAINT, Edit > PASTE
FILE > SAVE
Open folder that stores the saved screenshot, click it, top menu bar, EMAIL
Attach
Well, Ken, there's only one bit of information that you did NOT bring to our attention. What program are you using to PASTE it into... Microsoft Paint, Adobe Photoshop, Paint.NET ...what... This may make a HELL of a difference. :) And it will be easier to help with. I see that you said "Paint" but you could be, by chance using Paint.NET, because if you aren't I recommend it. It will make your life sooo much easier.
    Gateway® M-7315u
    Intel Pentium Dual Core T3200
    Stock
    4GB (2x2GB)
    Mobile Intel® 4 Series Express Chipset
    Conexant HD Audio & Intel HDMI Audio
    2x120GB HDD
    3 Qubes (3TB Total)
    The Battery. LOL
    Carbon Fiber Shell
    Copper Coiled Side Fan
    QWERTY Standard (Touch Sensitive Media Options)
    Microsoft Wireless Mouse 6000
    Comcast Business (35mbps)
    Cisco Linksys N+ Wireless
    3xUSB 2.0
    A-I-O Card Reader
    HD/DVD-ROM/RAM 12x
    100MBPS LAN Ethernet
As Joan said, the snipping tool is the easiest. When you open snipping tool, click on the arrow on the 'new button', select full screen, click the save icon in the window that pops up.
Gary
    Intel Core2 Quad Q6600
    Creative SB X-Fi
    HP w2207 + HPvs15
    1680x1050 + 1024x768
    2-WD5000AAKS-500 GB
    WD 5000AAV-500 GB external
    Microsoft Comfort Curve
    MX Revolution
    Wacom Intuos 2 Graphics Tablet
    Experience Index=5.5
Hello Ken,
Press PRNT SCRN
FILE > SAVE
Attach
^^^^^^^^^^^ easy as that ;)
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Razer Reclusa
    Logitech G5 Gamer
    8mb
So you do have to go through paint?... I was able to do a print screen and paste directly into Word... why can't I paste directly into email or other website.
Zyonix... I went to a Microsoft website and they said all you had to do was to hit alt/prnscreen and then go to where you wanted to display the image and just hit paste. There was no mention of any intermediary program that had to be used such as paint... and as I mentioned I was able to do this directly to a word document without having to go through any other programs
thanks,
ken
You say you've manged to save it to a Word document, what happens when you try to send that as email.
You haven't told us what email client you are using.
    Windows 10 Home
I can send it as an attachment from word using my email client... which is windows mail.. I also tried to do alt/print to this website and it did not work.
Hi kenshireen
Sorry to be the barer of bad news but there is a known problem with Windows Mail not able to accept pasted images directly. :cry:
This is AFAIK not been addressed by Microsoft, although it is not an issue with Windows Live Mail, which is generally considered a replacement / upgrade to Windows Mail
If you need to send an image with Windows mail you will have to create an image file and attach it to the mail.
Have a look here for live mail
Windows Live Mail
    2 x 1920x1080 @50Hz
    Asus M5A78L-M USB3
    32GB [4x8GB] DDR3 1600 MHz
    Asus nVidia GTX750TI-OC-2GD5 (2GB DDR5)
    Samsung 32" TV
    Internal
    Crucial CT256MX100SSD1 256GB SSD,
    Seagate ST2000DM001-1CH1 2TB,
    External (USB3)
    Seagate Backup+ Hub BK SCSI Disk 8TB
    2.5/3.5 Hot Swap Cradle, USB3 + eSata (client HDDs)
    NAS 4TB
    68 MB Down 18.5 MB Up
To send attachment to this website :
click Post Reply or Quote if you are replying to someone in particular
click the " paper-clip " icon
click BROWSE till you find the screenshot
click UPLOAD ( the top one )
wait till it's done uploading
do you reply messages
click paperclip, click the " .jpg "
click Submit Reply
click Submit Reply
I understand how to upload,the problem is how do I upload an image of window explorer... I am trying to show an image of a directory problem I am having.. So I need to capture a picture of the directory. How can I get this image to appear in the browse window..
Thank you again, Ken
In snipping tool, there is a capture window option. Snipping tool should be under accessories on the start menu.
Gary
    Creative SB X-Fi
    HP w2207 + HPvs15
    2-WD5000AAKS-500 GB
    MX Revolution
click Submit Reply
Press PRNT SCRN
FILE > SAVE
click Submit Reply
Press PRNT SCRN
FILE > SAVE
See attachment of my screenshot
SORRY...NO HELP...just a work-around...
That's a problem I have been having on my new VISTA machine with Windows Mail at home.
I can paste the screen capture into a Word doc or into an OpenOffice doc...but NOT into an e-mail. I do this all the time at work and it works just fine in OUTLOOK and my other programs. I also tried a screen capture from "MWSnap" (which works with my other programs, too). So, I just assumed that it is a bug with Microsoft Windows Mail software.
I've just resorted to a work-around and pasted into my doc and then saving and e-mailing the doc...a pain-in-the-behind but at least I can send the screen capture.
