Lorien
Account Suspended
Personally, if you have a genuine Vista Installation Disk, I would recommend a repair/upgrade over the image restore as you will not lose EVERYTHING that happened since over 2 months ago (though you will need to reinstall all the updates and Service Packs for Vista since what was on the Vista Disk) - but the decision is yours. Plus, if Repair/Upgrade doesn't work (and it might not), you can still do the other option and having tried the repair/upgrade will make no difference with that (but not vice-versa).
Good luck!
Good luck!
- Dell Inc. MP061 Inspiron E1705
- 2.00 gigahertz Intel Core 2 Duo 64 kilobyte primary memory
- Board: Dell Inc. 0YD479 Bus Clock: 166 megahertz
- 2046 Megabytes Usable Installed Memory
- Graphics Card(s)
- ATI Mobility Radeon X1400 (Microsoft Corporation - WDDM) [Di
- SigmaTel High Definition Audio CODEC
- Generic PnP Monitor (17.2"vis)
- 1920 x 1200 pixels
- Hitachi HTS541616J9SA00 [Hard drive] (160.04 GB) -- drive 0, s/n SB2411SJGLLRMB, rev SB4OC74P, SMART Status: Healthy
- Case
- Chassis Serial Number: 5YK95C1
- Standard PS/2 Keyboard
- Logitech HID-compliant Cordless Mouse
- 1958 Kbps download ; 754.8 Kbps upload
- Other Info
- Optiarc DVD+-RW AD-5540A ATA Device [CD-ROM drive]
Dell AIO Printer A940
6TO4 Adapter
Microsoft ISATAP Adapter
Router Linksys / WRT54G -01
