How to Repair Vista Business Edition?
rpaul
I purchased my laptop 2007 and it is running Vista Business Edition.
I faced problems when I tried to install .net framework 3.5. I have to repair my .net framework 2.0 and 3.0 which is part of the OS. I tried with the Windows Vista CD which I received when I purchased laptop. But, it comes back to me with a message that your key is expired. How can I get a copy of Vista to repair my Vista in my laptop?
Thanks
Do you have a recovery partition? to check go to -control panel-administrative tools-computer management-storage-disk management and see if you have anything under 15GB and saying Healthy Recovery partition. NOTE that it might not have a drive letter.eg C:\ D:\ E:\
    Custom Gaming Rig 780G
    AMG Athlon II X2 255 3.8/2MB/2500MHz 45nm AM3
    Gigabyte GA-MA78LMT-S2 AM3, Core Boost, Ultra Durable 3
    2X 4GB Kingston DDR3 1066MHz @ 1666MHz Dual Channel
    HIS HD Radeon 7770 GHz Edition iCooler Core: 1000MHz
    Realtek HD Audio
    Dell E2311H DVI/VGA 5ms response, Full HD
    1920x1080 @ 60Hz
    320GB Seagate Barracuda 7200.02 SATA II
    Cooler Master Extreme Power Plus 700w
    Lian-Li PC-6010 With Side Window
    Aywun A4 80mm fan
    Logitech K120 Wired Keyboard
    Logitech K120 Wired Mouse
    802.11B/G/N 17Mb/s
    AMD Catalyst 12.6
    Thomson A/B/G/N Router
    LiteON CD/DVD Player
    GAME PERFORMANCE:
    Battlefield 3: 41 FPS High 1x AA @ 1280x720
    Mass Effect 2 and 3: 60 FPS Highest 4x AA @ 1920x1080
    Counter Strike Source (and other Valve games):
    300 FPS (max FPS in game) Highest settings 8x AA 16x AF @ 1920x1080!!!
This probably wont work, but If you haven't already, try activating by telephone. This will sometimes fix activation issues that occur by activating over the internet, such as the "The product key is already in use" issue after re-installing Vista. Worth a shot. Or you can try what Nostaw5 said and look for the recovery partition if there is one.
Good Luck.
    Samsung R60 Plus
    Intel Core 2 Duo T7250 @ 2.00 Ghz
    2 GB DDR2 RAM
    ATI Radeon Xpress 1200 series
    Realtek Hi-def Audio
    Mobile PC Display
    Fujitsu 120 GB SATA drive
    100 mb/s
    South Korean model,
    Shipped from an english teacher half way across the world =P
