I need help with my Epson 645 printer?
A
Advice Pro
I just got the printer yesterday and today have printed twice, but can't print anymore and their printers help suggests to set the paper type in the printer software, I don't know what it is. It's none of these:
Hello, does the user guide give you any troubleshooting tips ?
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
All I can find is this:
Blank Pages Print
If blank pages print unexpectedly, try these solutions:
  • Make sure you selected the correct paper size settings in your printing program and printer software.
  • If a blank page exists in a document you are printing and you want to skip printing it, select the Skip Blank Page setting in your printer software.
  • Run a print head nozzle check to see if any of the nozzles are clogged. Then clean the print head, if necessary.
  • Make sure your product is selected as the printer in your printing program.
How does that work when you attempt that ?
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
