You should upgrade or use an
alternative browser .
InfraRecorder Smoke Effect??
Using a program called InfraRecorder. It works fine except I don't get the SMOKE effect. It's checked in the settings and AERO is enable in Vista, so I don't know the problem.
Anyone have a suggestion?
AMD/GIGABYTE
AMD Athlon(tm) 64 X2 Dual Core Processor 6000+ (2 CPUs), ~3.
Gigabyte GA-M57SLI-S4 (rev. 2.0)
2048MB RAM
NVIDIA GeForce 8600 GT
SyncMaster T220/T220G,SyncMaster Magic T220/T220G(Digital)
1680 by 1050 pixels
Seagate ST310003 40AS SCSI Disk Device
Western Digital WDC WD50 00AAJS-00YFA SCSI Disk Device
Thermaltake 500W
VERY FAST>>>>!!!!
Optiarc DVD RW AD-7191S SCSI CdRom Device
Do you have DirectX 9.0c installed?
Compaq/SR5130NX
AMD AthlonTM 64x2 3800+
NVIDIA GeForce 6150 SE
I am using Windows 7 now, and it has DirectX 11 by default. Also, the smoke effect works but only when burning DVD/CD. Not when transferring DVD/CD to PC.
AMD/GIGABYTE
2048MB RAM
1680 by 1050 pixels
Thermaltake 500W
VERY FAST>>>>!!!!
