Internet Explorer Icon
How to Create a Fully Functional "Internet Explorer" Desktop Icon Shortcut in Vista
This will show you how to create a Internet Explorer shortcut that has the Open Home Page, Start without Add-ons, and Internet Properties in the context menu.
This does not work in Windows 7.
The default location for the Internet Explorer exe file is at:
64 bit Windows: C:\Program Files (x86)\Internet Explorer\iexplore.exe
32 bit Windows: C:\Program Files\Internet Explorer\iexplore.exe
EXAMPLE: Fully Functional Internet Explorer Shortcut
NOTE:
Properties opens Internet Properties, not the shortcut's properties.
OPTION ONE
If You Use the Normal (Default) Start Menu
1. To Add Internet Explorer Shortcut
AddIE7IconTo Desktop.reg
download
B) Go to step 3.​
2. To Remove Internet Explorer Shortcut
NOTE: You can also right click on the shortcut and click Delete.​
RemoveIE7IconFrom Desktop.reg
download
3. Click on Save, and save the reg file to the Desktop.​
4. Right click on the downloaed .reg file, and click on Merge.​
5. Click on Run , Continue (UAC-Vista) or Yes (UAC-Windows 7), Yes, OK when prompted.​
6. You may need to right click on a empty area of your desktop and click on Refresh or press F5 to see the new Icon.​
7. When done, you can delete the downloaded .reg file if you like​
OPTION TWO
If You Use the Classic Start Menu
AddIE7IconTo ClassicDesktop.reg
download
B) Go to step 3.​
RemoveIE7IconFromClassicDesktop.reg
download
5. Click on Run , Continue (UAC), Yes, OK when prompted.​
  • AddIE7IconToDesktop.reg
  • RemoveIE7IconFromDesktop.reg
  • AddIE7IconToClassicDesktop.reg
  • RemoveIE7IconFromClassicDesktop.reg
Updated to include a IE7 Icon for the Classic Start Menu.
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
