Lock Computer - Enable or Disable
How to Enable or Disable Lock Computer in Vista
This will show you how to Enable or Disable Lock computer from working, and add or remove it from the Windows Security screen when you press CTRL+ALT+DEL for all user accounts on the computer. Lock is enabled in Vista and is listed in the CTRL+ALT+DEL menu by default.
When the computer is locked, the desktop is hidden and the system cannot be used. Only the user who locked the computer or the system administrator can unlock it with their password (if created).
This will not add or remove Lock from the Start menu. It will only enable or disable Lock from working when clicked on.
EXAMPLE: Default (Added) and Removed Lock this computer in Ctrl+Alt+Del
OPTION ONE
NOTE: This option is only available for the Vista Business, Ultimate, and Enterprise editions. See OPTION TWO or OPTION THREE below for the Vista Home Basic and Home Premium editions.
2. In the left pane, click on User Configuration, Administrative Templates, System, and Ctrl+Alt+Del Options. (See screenshot below)​
3. In the right pane, right click on Remove Lock Computer and click on Properties. (See screenshot above)​
4. To Enable and Add Lock Computer
A) Dot Disabled or Not Configured and click on OK. (See screenshot below step 5A)​
B) Go to step 6.​
5. To Disable and Remove Lock Computer
A) Dot Enabled and click on OK.​
OPTION TWO
Using a REG File Download
NOTE: This option will work in all Vista editions.
1. To Enable and Add Lock Computer
Add_Enable_Lock_CtrlAltDel.reg
download
B) Go to step 3.​
2. To Disable and Remove Lock Computer
Remove_Disable_Lock_CtrlAltDel.reg
download
6. Log off and log on, or restart the computer to apply the changes.​
7. When done, you can delete the .reg file if you like.​
OPTION THREE
Manually in Registry Editor
1. Open the Start Menu.​
4. In regedit, go to: (See screenshot below step 5C)​
NOTE: If you do not have System, then right click on Polices and click on New and Key, then type System and press Enter.
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System
A) In the right pane, right click on a empty area and click on New and DWORD (32-bit) Value. (See screenshot below step 5C)​
B) Type DisableLockWorkstation and press Enter. (See screenshot below step 5C)​
C) Right click on DisableLockWorkstation and click on Modify. (See screenshot below)​
6. To Enable and Add Lock Computer
A) In the right pane, right click on DisableLockWorkstation and click Delete. (See screenshot below step 5C)​
B) Click on Yes to confirm the deletion.​
7. Close regedit.​
  • Add_Enable_Lock_CtrlAltDel.reg
  • Remove_Disable_Lock_CtrlAltDel.reg
