mass storage controller???
Thank you for your feedback.
Computer terminology can confuse!!
I totally agree with Richc's advice & option for you.
```it will be easier to understand yet achieve the same end.
Let us know how you get on.
‘I do not seek to follow in the footsteps
of the men of old,
I seek the things they sought‘
Basho (1644-1694) Japanese Haiku
see my last reply to richc..thanks!
    Gateway
See my last reply to you.
Ask whatever you do not understand.
Trust me, I want to help and will be patient.
If the instructions that I gave (which is the best way to update drivers) is not appropriate for you, try it this way:
Driver Install - Device Manager - Windows 7 Forums
Applicable for Vista and Seven.
The best way for you, then, is to try the above.
with these instrustions i get stuck on step 2, there is no option for "device manager" this is what i see:
http://i55.tinypic.com/30j5pi8.jpg
@kesume, this is what i said to richc, i get stuck with the instructions.
    Gateway
thank you, i was following the last link you gave me for the driver install, but i am getting stuck on step 2 where it says to click device manager....i am not given that option and cant go any further.. i included a picture in my last reply to show you exactly what comes up
    Gateway
Your in the wrong place
Go to search, its by the windows start button.
Type device mangager.
I think that would be the best way for you.
okay i am at this link you gave me
and the first step tells me to go exactly here? are these not the directions i am supposed to be following?
i know how to get to my device manager if this is where you want me to go, i was just going by the new instuctions..
    Gateway
sorry, i didnt look ahead at the directions after i got stuck. i didnt realize it was just taking me to my device manager...let me see if i can follow the instructions now...
    Gateway
Take your time
The instructions are quite clear.
okay now the main problem i run into is that i CANT right click on the mass storage controller or any other thing in my device manager. when i right click nothing happens.
    Gateway
Try left click
I think this is the driver you are after.
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
Try the windows update.
Make sure it is set to download drivers
Windows Update Settings - Change - Windows 7 Forums
Applicable to Seven and Vista.
Then read this aritcle
Update a driver for hardware that isn't working properly
i changed the setting so that i could manually update drivers but it still doesnt let me right click or anything. i tried to do a windows update but i get this error each time i try: http://i52.tinypic.com/2je7ofs.jpg
ive already tried to follow the directions to fix the error but nothing was set differently than the directions told me.
    Gateway
thank you. if this is the driver i need, for whatever reason...when i try to open the folder it tells me windows explorer stopped working and i have to restart it. this happens every time i try. so i cant get into the folder.
    Gateway
Elizabeth,
If I only assume that you are following instructions carefully, I must come to the conclusion that you have more problems than you realize.
Follow these instructions,
It will find and solve some of the problems.
If errors are found run three times and then let us know.
We will tell you how to send the report to us.
http://www.vistax64.com/tutorials/66978-system-files-sfc-command.html
Also the file I gave you is a zip file, you have to right click and extract it first then run the setup.exe by double clicking or right click and run as administrator.
Do the sfc scan first as Richc46 has said.
    LENOVO 64734VM
    15 inch
    External Speakers
Elizabeth,
okay i did the scan once and errors were found. it said they were removed and to restart the computer. since you said to do it 3 times i tried it again but it said there was a repair pending and that i needed to reboot then to run it again. but i restarted twice and it still says this.so i cant follow any of the other steps or it says this.
    Gateway
Could you go to c,windows,logs.cbs and right click cbs and send to compressed(zip)folder
On your next post click on the paperclip and browse to the zip folder and click upload,
close the box when it has finished.
    LENOVO 64734VM
    15 inch
    External Speakers
if i were to just to the total factory reset of my computer do you think its likely the problems will go away?i have done it once before to fix a virus so i can do it again if you think it will fix it instead of going through all these steps to figure out what is wrong with it. i can save all my documents on a flash drive or do the reset that keeps your files..
    Gateway
