Menu Bar
How to Enable or Disable the Menu Bar in Vista Windows Explorer
This is the toolbar at the top of a Windows Explorer window with menus. By default, Vista has the Menu bar disabled.
The Menu bar includes the File, Edit, View, Favorites (In IE7), Tools, and Help menus.
EXAMPLE: Menu Toolbar Enabled
EXAMPLE: Menu Toolbar Disabled
METHOD ONE
Using a Keyboard Shortcut
NOTE: This will only temporarily show the Menu bar in Windows Explorer. It will go away as soon as you click on something other than the menu. To turn it on all the time, see the methods below.
1. Press the Alt key to just see the Menu bar to click on a menu item to open it.​
OR
2. Press the Alt + (underlined letter) keys to open the menu item with that underlined first letter.​
METHOD TWO
Through Windows Explorer
1. Open a Windows Explorer window.​
2. Click on Organize and Layout. (See screenshot below)​
3. To Enable the Menu Bar
A) Click on Menu Bar to check it.​
4. To Disable the Menu Bar
A) Click on Menu Bar to uncheck it.​
METHOD THREE
Through Folder Options
1. Open Folder Options.​
2. Click on the View tab. (See screenshot below)​
A) Check Always show menus.​
B) Go to step 5.​
A) Uncheck Always show menus.​
5. Click on OK.​
METHOD FOUR
Using a REG File Download
1. To Add the Menu Bar
Add_Menu_Bar.reg
download
B) Go to step 3.​
2. To Remove the Menu Bar
Remove_Menu_Bar.reg
download
4. Right click on the downloaded .reg file and click Merge.​
7. Log off and log on, or restart the computer to apply the changes.​
8. When done, you can delete the downloaded .reg file if you like.​
METHOD FIVE
Through Registry Editor
1. Open the Start Menu.​
4. In regedit, navigate to the location below.​
Code:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced
5. To Add the Menu Bar
A) In the right pane, right on AlwaysShowMenus and click on Modify.​
B) Type 1 and click on OK.​
C) Go to step 7.​
6. To Remove the Menu Bar
B) Type 0 (number zero) and click on OK.​
7. Close regedit.​
8. Log off and log on, or restart the computer to apply the changes.​
  • Remove_Menu_Bar.reg
  • Add_Menu_Bar.reg
the problem is that it does not work for me.
Moreover,when i press on organize i do not see the whole options i see in the screenshot.
i ran a lot of antivirus checks but did not find anything
any suggestion?
Hello Ahmad Abdullah, and welcome to Vista Forums.
Have you tried any of the other methods to see if they can enable the Menu bar for you?
If you have, could you post a screenshot of this area to see if it may help determine what may be a cause?
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
no thanks
after i posted her i made a search on bing to find that the solotion is
go to folder options and from the general tap>>>>> sow preview and filters
just like that .:D
te problem h interrupted me for more than 2 monthes and it also happened on win server
thank u
I'm happy to hear that you got it sorted. :)
