Navigation Pane - Simple Folder View
How to Hide or Show the Navigation Pane Folders Tree Lines in Vista
This will show you how to hide or show the folder tree lines in the lower Folders section of the Navigation pane.
If you have the Windows Explorer window open, you will need to close it and reopen it to see the changes made below.
EXAMPLE: Folders Tree with Lines set to Hide and Show
NOTE:
The left screenshot is with simple folder view displayed.
METHOD ONE
Using Folder Options
1. Open Folder Options.​
2. To Hide the Folders Tree Lines
A) Check Display simple folder view in Navigation pane. (See screenshot below step 4)​
B) Go to step 4.​
3. To Show the Folders Tree Lines
NOTE: This is the default setting.​
A) Uncheck Display simple folder view in Navigation pane. (See screenshot below)​
4. Click on OK to apply.​
NOTE: If you have the Windows Explorer window open, you will need to close it and reopen it to see the changes.​
METHOD TWO
Using a REG File Download
1. To Hide the Folders Tree Lines
Hide_Folder_Tree_Lines.reg
download
B) Go to step 3.​
2. To Show the Folders Tree Lines
Show_Folder_Tree_Lines.reg
download
6. If open, close and reopen the Windows Explorer window to see the change.​
7. When done, you can delete the downloaded .reg file if you like.​
  • Show_Folder_Tree_Lines.reg
  • Hide_Folder_Tree_Lines.reg
