VFN
Closed IE8 and a notepad doc is on my screen. Properties says it's a log. Scanned it but haven't opened it. Did I inadvertently hit a key(s) to create this? I think I've seen this happen before.
Thanks.
Okay. Opened it and it's a Java error log.
" A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_PRIV_INSTRUCTION (0xc0000096) at pc=0x081327e1, pid=4784, tid=5092
# JRE version: 6.0_27-b07
# Java VM: Java HotSpot(TM) Client VM (20.2-b06 mixed mode, sharing windows-x86 )
# Problematic frame:
# C 0x081327e1.......
# The crash happened outside the Java Virtual Machine in native code."
Will reinstall.
Thanks.
Thanks.
Will reinstall.
Thanks.
- Operating System
- Vista Home Premium x64
- Dell Inspiron 546
- Sempron LE-1300
- 2GB DDR SDRAM 800MHZ-2X1GB DIM M
- Graphics Card(s)
- Integrated ATI Radeon HD3200
- VIA High Definition Audio
- Samsung 32" HDTV
- 1366 x 768
- 320GB NCQ Serial ATA (7200 RPM) w/ 16MB DataBurst Cache
