Peer Guardian (Running but not working)
MrElectrifyer
Electrical Engineer
I managed to install and run the Peerguardian 2 software on my vista home premium 64 bit, but i does not appear to be doing any work, it doesn't show anything being allowed nor blocked, it only shows "Blocking 1016306150 IPs". Is there anywhere I can find a working version of the software? :rolleyes:
    HP Pavilion dv3510nr Entertainment Notebook PC
    Intel(R) Core(TM)2 Duo CPU P7350 @ 2.00GHz
    Inventec 1505
    4.00GB
    NVIDIA GeForce 9300M GS
    Generic PnP Monitor
    WDC WD3200BEVT-00ZCT0
    Standard 101/102-Key or Microsoft Natural PS/2 Keyboard with
    Alps Pointing-device
    Airbot 2.0
    EVGA Nvidia GTX 480 -Fermi
    ASUS Xonar D2X
    1920x1080@60hz
    1 OCZ Vertex2 180GB SSD
    Pioneer DVD Burner DVR-S18M
    Corsair HX1000W
    Cooler Master HAF 932
    Logitech Wireless MK700
    Windows 7
    W.E.I final score= 7.7
    Windows Vista=5.9
I went into the compatibility tab of the icon's properties but the option to Run in compatibility mode is greyed out, I can't select it.
    Inventec 1505
    4.00GB
    Generic PnP Monitor
The tutorial has a note at the 3rd step, pointing to another tutorial to manually add it. Have you tried running it as administrator?
    Airbot 2.0
    ASUS Xonar D2X
    1920x1080@60hz
    Corsair HX1000W
    Windows 7
    Windows Vista=5.9
Sorry to say this, but I am kind of new to this Vista forum so could you be specific of the tutorial you are refering to. Yes I have tried running it as an administrator, no difference.
    Inventec 1505
    4.00GB
    Generic PnP Monitor
    Airbot 2.0
    ASUS Xonar D2X
    1920x1080@60hz
    Corsair HX1000W
    Windows 7
    Windows Vista=5.9
I have set it to run in compatibility mode but there is still no change, it is still only showing that it is blocking IPs, it is not showing any activity as I surf the web, do you know where I can find a different download of this software for vista? If you are using it, perhaps the one you are using will be a good link to send me.
    Inventec 1505
    4.00GB
    Generic PnP Monitor
I do not use this program. The site says it works for Vista but not 64 bit. It might just not work properly in 64 bit.
    Airbot 2.0
    ASUS Xonar D2X
    1920x1080@60hz
    Corsair HX1000W
    Windows 7
    Windows Vista=5.9
