Pop-Up Description
How to Turn Pop-Up Descriptions On or Off in Vista
This will show you how to turn pop-up descriptions when you move the mouse pointer over a folder or desktop item on or off. This is turned on by default.
This is one of the only ways to see the size of a folder. The other way is to right click on the folder and click Properties.
EXAMPLE: Pop-up Description
OPTION ONE
Through Folder Options
1. Open Folder Options.​
2. Click on the View tab. (See screenshot below step 4)​
3. To Turn Off Pop-up Descriptions
A) Uncheck the Show pop-up description for folder and desktop items box.​
B) Click on OK.​
4. To Turn On Pop-up Descriptions
A) Check the Show pop-up description for folder and desktop items box.​
B) Click on OK.​
OPTION TWO
Using a REG File Download
1. To Enable Pop-Up Descriptions
Enable_Pop-Ups.reg
download
B) Go to step 3.​
2. To Disable Pop-Up Descriptions
Disable_Pop-Ups.reg
download
OPTION THREE
Manually in Registry Editor
1. Open the Start Menu.​
3. If prompted, click on the Continue button in the UAC prompt.​
4. In regedit, go to: (See screenshot below step 5)​
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced
5. In the right pane, right click on ShowInfoTip and click Modify.​
6. To Enable Pop-Up Descriptions
A) Type 1 and click on OK. (See screenshot below)​
B) Go to step 8.​
7. To Disable Pop-Up Descriptions
A) Type 0 (number zero) and click on OK
8. Close regedit.​
  • Disable_Pop-Ups.reg
  • Enable_Pop-Ups.reg
