Programs and Features - Disable or Enable
How to Disable or Enable Programs and Features in Vista
This will show you how to enable or disable access of Programs and Features in the Control Panel to view, uninstall, change, or repair programs that are currently installed on the computer for all users.
This will not prevent a program from being uninstalled by a 3rd party program or manually from the program's uninstaller in it's C:\Program Files folder.
EXAMPLE: Programs and Features Disabled
OPTION ONE
2. In the left pane, click on User Configuration, Administrative Templates, Control Panel, and Programs. (See screenshot below)​
3. In the right pane, right click on Hide "Programs and Features" page and click on Properties. (See screenshot above)​
4. To Enable Programs and Features
B) Go to step 6.​
5. To Disable Programs and Features
OPTION TWO
Using a REG File Download
1. To Enable Programs and Features
Enable_Programs_and_Features.reg
download
B) Go to step 3.​
2. To Disable Programs and Features
Disable_Programs_and_Features.reg
download
4. Right click on the download .reg file and click on Merge.​
5. Click on Run, Continue (UAC), Yes, and then on OK when prompted.​
OPTION THREE
Manually in Registry Editor
1. Open the Start Menu.​
NOTE: If Programs is not there, then right click on Policies and click on New and Key. Type Programs and press Enter.​
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Programs
A) In the right pane, right click on a empty area and click on New and on DWORD (32-bit) Value. (See screenshot above)​
B) Type NoProgramsAndFeatures and press Enter.​
C) Right click on NoProgramsAndFeatures and click on Modify. (See screenshot below)​
F) Go to step 7.​
6. To Enable Programs and Features
A) In the right pane, right click on NoProgramsAndFeatures and click on Delete. (See screenshot above)​
7. Close regedit.​
  • Disable_Programs_and_Features.reg
  • Enable_Programs_and_Features.reg
