When doing an analysis using CCleaner the memory dump file is almost 600MB. CCleaner will clean out the Memory Dump, but my question is, is it safe to do so? I realize this is used for system recovery, but not sure just how. Thanks for any help.
Memory dump files are only necessary if you're having a problem with the system and want to use it to help diagnose the problem.
In short, if you're unsure, leave any recent ones but delete those that are older.
You can also set the system to create minidumps (which are much smaller) using this link: Change dump file location & size to Minidumps - Vox
The 600 MB file = full kernel dump - that can go as each BSOD would overwrite it - location = \windows\memory.dmp
The minidumps located in \windows\minidump - new ones are created using date as part of the file name. I would keep the newer ones as they can & do often aid in finding the cause of BSODs by showing a pattern (or not). I would consider "newer" ~ 3 months
If you do find any minidumps, start a BSOD thread to have them looked at.
