Recent Items - Clear Document History on Exit
How to Enable or Disable Clear Recent Document Items History on Exit
This will show you how to enable or disable Vista to clear the recently opened documents history for when the current user account logs off. This way the Recent Items menu button on the Start menu is always empty when the user logs on. This is disable by default in Vista.
If you have only one user account on your computer that is shared with other users, then this can be handy to keep each user's recently opened document history private when they log off or shutdown.
This does not clear the Recent Programs history on exit. This will still need to be manually done.
EXAMPLE: Recent Items Menu Button on the Start Menu
OPTION ONE
NOTE: This option is only available for the Vista Business, Ultimate, and Enterprise editions. See OPTION TWOor OPTION THREE below for the Vista Home Basic and Home Premium editions.
2. In the left pane, click on User Configuration, Administrative Templates, and Start Menu and Taskbar. (See screenshot below)​
3. In the right pane, right click on Clear history of recently opened documents on exit and click on Properties. (See screenshot above)​
4. To Enable Clear Recent Items History on Exit
B) Go to step 6.​
5. To Disable Clear Recent Items History on Exit
OPTION TWO
Using a REG File Download
NOTE: This option will work for all Vista editions.
1. To Enable Clear Recent Items History on Exit
Enable_Clear_Recent_Item_On_Exit.reg
download
B) Go to step 3.​
2. To Disable Clear Recent Items History on Exit
Disable_Clear_Recent_Item_On_Exit.reg
download
OPTION THREE
Manually in Registry Editor
1. Open the Start Menu.​
NOTE: If you do not have Explorer, then right click on Polices and click on New and Key. Type Explorer and press Enter.
5. To Enable Clear Recent Items History on Exit
A) In the right pane, right click on a empty area and click on New and DWORD (32-bit) Value. (See screenshot above)​
B) Type ClearRecentDocsOnExit and press Enter.​
C) Right click on ClearRecentDocsOnExit and click on Modify. (See screenshot below)​
F) Go to step 7.​
6. To Add Log Off to the Ctrl+Alt+Del Screen
A) In the right pane, right click on ClearRecentDocsOnExit and click on Delete. (See screenshot above)​
7. Close regedit.​
  • Disable_Clear_Recent_Items_On_Exit.reg
  • Enable_Clear_Recent_Items_On_Exit.reg
