Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Loading Dump File [C:\Users\richc46\AppData\Local\Temp\Temp1_Mini070410-03%20(2)[1].zip\Mini070210-01.dmp]
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows Server 2008/Windows Vista Kernel Version 6002 (Service Pack 2) MP (2 procs) Free x86 compatible
Built by: 6002.18209.x86fre.vistasp2_gdr.100218-0019
Machine Name:
Kernel base = 0x82441000 PsLoadedModuleList = 0x82558c70
Debug session time: Fri Jul 2 21:45:53.382 2010 (GMT-4)
System Uptime: 0 days 0:00:25.272
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
BugCheck D1, {4, 2, 0, 889629f8}
Probably caused by : ecache.sys ( ecache!EcBlockFind+62 )
Followup: MachineOwner
1: kd> !analyze -v
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: 00000004, memory referenced
Arg2: 00000002, IRQL
Arg3: 00000000, value 0 = read operation, 1 = write operation
Arg4: 889629f8, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from 82578868
Unable to read MiSystemVaType memory at 82558420
00000004
CURRENT_IRQL: 2
FAULTING_IP:
889629f8 8b5004 mov edx,dword ptr [eax+4]
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0xD1
PROCESS_NAME: lsass.exe
TRAP_FRAME: 92583b0c -- (.trap 0xffffffff92583b0c)
ErrCode = 00000000
eax=00000000 ebx=00000000 ecx=00013580 edx=00000000 esi=ffffffff edi=88977540
eip=889629f8 esp=92583b80 ebp=92583b94 iopl=0 nv up ei pl zr na pe nc
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010246
ecache!EcBlockFind+0x62:
889629f8 8b5004 mov edx,dword ptr [eax+4] ds:0023:00000004=????????
Resetting default scope
LAST_CONTROL_TRANSFER: from 889629f8 to 8248efd9
STACK_TEXT:
92583b0c 889629f8 badb0d00 00000000 824e9b15 nt!KiTrap0E+0x2e1
92583b94 88964982 88977540 86a390d8 00013580 ecache!EcBlockFind+0x62
92583c08 88969a02 86a390d8 00a18008 00000001 ecache!EcCacheBootIsIrpInCache+0xae
92583cd0 824859c6 86a39020 87a18008 87a18190 ecache!EcDispatchReadWrite+0xe6
92583ce8 88913033 92583d38 86a3a020 92d74d00 nt!IofCallDriver+0x63
92583d08 824859c6 86a3a020 87a18008 925a17cc volsnap!VolSnapRead+0x14d
92583d20 88812603 925a1754 92583d44 824ee1f8 nt!IofCallDriver+0x63
92583d2c 824ee1f8 925a17cc 00000000 ffffffff Ntfs!NtfsStorageDriverCallout+0x14
92583d2c 824ee2f1 925a17cc 00000000 ffffffff nt!KiSwapKernelStackAndExit+0x118
925a1764 00000000 00000000 00000000 00000000 nt!KiSwitchKernelStackAndCallout+0x31
STACK_COMMAND: kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 1
SYMBOL_NAME: ecache!EcBlockFind+62
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: ecache
IMAGE_NAME: ecache.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 49e01f2c
FAILURE_BUCKET_ID: 0xD1_ecache!EcBlockFind+62
1: kd> lmtsmn
start end module name
8cc6f000 8cc7c080 1394BUS 1394BUS.SYS Sat Jan 19 00:53:27 2008 (47919057)
82a89000 82acf000 acpi acpi.sys Sat Apr 11 00:19:03 2009 (49E01A37)
8ef85000 8efcd000 afd afd.sys Sat Apr 11 00:47:01 2009 (49E020C5)
8cd1d000 8cd49000 Apfiltr Apfiltr.sys Thu Apr 12 03:02:55 2007 (461DD99F)
8efcd000 8efd1100 aswRdr aswRdr.SYS Thu May 06 16:34:25 2010 (4BE327D1)
883c7000 883ed680 aswSP aswSP.SYS Thu May 06 16:38:58 2010 (4BE328E2)
8ef67000 8ef70c00 aswTdi aswTdi.SYS Thu May 06 16:39:21 2010 (4BE328F9)
8835f000 88367000 atapi atapi.sys Sat Apr 11 00:39:09 2009 (49E01EED)
88367000 88385000 ataport ataport.SYS Sat Apr 11 00:39:10 2009 (49E01EEE)
8cc30000 8cc5f000 b57nd60x b57nd60x.sys Mon Feb 26 17:50:32 2007 (45E36438)
82b19000 82b23000 BATTC BATTC.SYS Sat Jan 19 00:32:45 2008 (47918B7D)
8eedb000 8eee2000 Beep Beep.SYS Sat Jan 19 00:49:10 2008 (47918F56)
80689000 80691000 BOOTVID BOOTVID.dll Sat Jan 19 02:27:15 2008 (4791A653)
81cd0000 81cde000 cdd cdd.dll unavailable (00000000)
8cd5f000 8cd77000 cdrom cdrom.sys Sat Apr 11 00:39:17 2009 (49E01EF5)
806d2000 807b2000 CI CI.dll Sat Apr 11 02:25:22 2009 (49E037D2)
88998000 889b9000 CLASSPNP CLASSPNP.SYS Sat Apr 11 00:39:05 2009 (49E01EE9)
80691000 806d2000 CLFS CLFS.SYS Sat Apr 11 00:13:51 2009 (49E018FF)
8cd77000 8cd7a780 CmBatt CmBatt.sys Sat Jan 19 00:32:47 2008 (47918B7F)
82b16000 82b18900 compbatt compbatt.sys Sat Jan 19 00:32:47 2008 (47918B7F)
889f2000 889ff000 crashdmp crashdmp.sys Sat Apr 11 00:39:12 2009 (49E01EF0)
889b9000 889c2000 crcdisk crcdisk.sys Thu Nov 02 04:52:27 2006 (4549B1CB)
887ca000 887e1000 dfsc dfsc.sys Sat Apr 11 00:14:12 2009 (49E01914)
88987000 88998000 disk disk.sys Sat Apr 11 00:39:14 2009 (49E01EF2)
8ec8a000 8ecaf000 drmk drmk.sys Sat Jan 19 01:53:02 2008 (47919E4E)
8870c000 887ca000 dump_iaStor dump_iaStor.sys Mon Feb 12 15:46:47 2007 (45D0D237)
8c800000 8c80a000 Dxapi Dxapi.sys Sat Jan 19 00:36:12 2008 (47918C4C)
8c539000 8c5d8000 dxgkrnl dxgkrnl.sys Sat Apr 11 00:23:43 2009 (49E01B4F)
88960000 88987000 ecache ecache.sys Sat Apr 11 00:40:12 2009 (49E01F2C)
883b7000 883c7000 fileinfo fileinfo.sys Sat Jan 19 00:34:27 2008 (47918BE3)
88385000 883b7000 fltmgr fltmgr.sys Sat Apr 11 00:13:59 2009 (49E01907)
8eecb000 8eed4000 Fs_Rec Fs_Rec.SYS Sat Jan 19 00:27:57 2008 (47918A5D)
886f1000 8870c000 fwpkclnt fwpkclnt.sys Sat Apr 11 00:45:42 2009 (49E02076)
8240e000 82441000 hal halmacpi.dll Sat Apr 11 00:13:13 2009 (49E018D9)
8c80c000 8c899000 HDAudBus HDAudBus.sys Sat Apr 11 00:42:41 2009 (49E01FC1)
8edef000 8edff000 HIDCLASS HIDCLASS.SYS Sat Apr 11 00:42:47 2009 (49E01FC7)
8eeeb000 8eef1380 HIDPARSE HIDPARSE.SYS Sat Jan 19 00:53:16 2008 (4791904C)
8ee00000 8ee09000 hidusb hidusb.sys Sat Apr 11 00:42:48 2009 (49E01FC8)
8ee0a000 8eebe000 HSX_CNXT HSX_CNXT.sys Thu Nov 02 22:42:05 2006 (454AAC7D)
8ecec000 8edef000 HSX_DPV HSX_DPV.sys Thu Nov 02 22:43:26 2006 (454AACCE)
8ecaf000 8ecec000 HSXHWAZL HSXHWAZL.sys Thu Nov 02 22:42:16 2006 (454AAC88)
8cd0a000 8cd1d000 i8042prt i8042prt.sys Sat Jan 19 00:49:17 2008 (47918F5D)
882a1000 8835f000 iastor iastor.sys Mon Feb 12 15:46:47 2007 (45D0D237)
88201000 882a1000 iastorv iastorv.sys Fri Oct 06 14:01:40 2006 (45269A04)
82b7c000 82b83000 intelide intelide.sys Sun Jan 07 22:45:40 2007 (45A1BE64)
889e3000 889f2000 intelppm intelppm.sys Sat Jan 19 00:27:20 2008 (47918A38)
8cd54000 8cd5f000 kbdclass kbdclass.sys Sat Jan 19 00:49:14 2008 (47918F5A)
8ec00000 8ec09000 kbdhid kbdhid.sys Sat Apr 11 00:38:40 2009 (49E01ED0)
80601000 80608000 kdcom kdcom.dll Sat Apr 11 02:25:29 2009 (49E037D9)
8c928000 8c952000 ks ks.sys Sat Apr 11 00:38:47 2009 (49E01ED7)
88408000 88479000 ksecdd ksecdd.sys Mon Jun 15 08:48:53 2009 (4A364335)
80608000 80678000 mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Apr 11 02:23:19 2009 (49E03757)
8eebe000 8eecb000 modem modem.sys Sat Jan 19 00:57:16 2008 (4791913C)
887e1000 887f0000 monitor monitor.sys Sat Jan 19 00:52:19 2008 (47919013)
8cd49000 8cd54000 mouclass mouclass.sys Sat Jan 19 00:49:14 2008 (47918F5A)
8c9f4000 8c9fc000 mouhid mouhid.sys Sat Jan 19 00:49:16 2008 (47918F5C)
82b98000 82ba8000 mountmgr mountmgr.sys Sat Jan 19 00:49:13 2008 (47918F59)
8ef2f000 8ef3a000 Msfs Msfs.SYS Sat Jan 19 00:28:08 2008 (47918A68)
82ad8000 82ae0000 msisadrv msisadrv.sys Sat Jan 19 00:32:51 2008 (47918B83)
8cd84000 8cdb3000 msiscsi msiscsi.sys Sat Apr 11 00:40:07 2009 (49E01F27)
88584000 885af000 msrpc msrpc.sys Sat Apr 11 00:37:32 2009 (49E01E8C)
8c952000 8c95c000 mssmbios mssmbios.sys Sat Jan 19 00:32:55 2008 (47918B87)
88951000 88960000 mup mup.sys Sat Apr 11 00:14:12 2009 (49E01914)
88479000 88584000 ndis ndis.sys Sat Apr 11 00:45:52 2009 (49E02080)
8c8b0000 8c8bb000 ndistapi ndistapi.sys Sat Jan 19 00:56:24 2008 (47919108)
8c8bb000 8c8de000 ndiswan ndiswan.sys Sat Apr 11 00:46:31 2009 (49E020A7)
8c99e000 8c9af000 NDProxy NDProxy.SYS Sat Jan 19 00:56:28 2008 (4791910C)
8efe8000 8eff6000 netbios netbios.sys Sat Jan 19 00:55:45 2008 (479190E1)
8c9af000 8c9e1000 netbt netbt.sys Sat Apr 11 00:45:35 2009 (49E0206F)
885af000 885ea000 NETIO NETIO.SYS Sat Apr 11 00:46:21 2009 (49E0209D)
8ca01000 8cc30000 NETw4v32 NETw4v32.sys Wed Sep 26 09:12:18 2007 (46FA5AB2)
8ef3a000 8ef48000 Npfs Npfs.SYS Sat Apr 11 00:14:01 2009 (49E01909)
8eff6000 8f000000 nsiproxy nsiproxy.sys Sat Jan 19 00:55:50 2008 (479190E6)
82441000 827fa000 nt ntkrpamp.exe Thu Feb 18 06:01:28 2010 (4B7D1E08)
88800000 88910000 Ntfs Ntfs.sys Sat Apr 11 00:14:34 2009 (49E0192A)
8eed4000 8eedb000 Null Null.SYS Sat Jan 19 00:49:12 2008 (47918F58)
8be0c000 8c538940 nvlddmkm nvlddmkm.sys Mon Jun 09 11:16:58 2008 (484D496A)
8cc5f000 8cc6e300 ohci1394 ohci1394.sys Sat Apr 11 00:43:04 2009 (49E01FD8)
8efd2000 8efe8000 pacer pacer.sys Sat Apr 11 00:45:51 2009 (49E0207F)
82b07000 82b16000 partmgr partmgr.sys Sat Apr 11 00:39:19 2009 (49E01EF7)
82ae0000 82b07000 pci pci.sys Sat Apr 11 00:19:16 2009 (49E01A44)
82b91000 82b98000 pciide pciide.sys Sat Apr 11 00:39:10 2009 (49E01EEE)
82b83000 82b91000 PCIIDEX PCIIDEX.SYS Sat Apr 11 00:39:09 2009 (49E01EED)
8ec5d000 8ec8a000 portcls portcls.sys Sat Apr 11 00:42:48 2009 (49E01FC8)
80678000 80689000 PSHED PSHED.dll Sat Apr 11 02:25:32 2009 (49E037DC)
8ef48000 8ef51000 rasacd rasacd.sys Sat Jan 19 00:56:31 2008 (4791910F)
8c899000 8c8b0000 rasl2tp rasl2tp.sys Sat Jan 19 00:56:33 2008 (47919111)
8c8de000 8c8ed000 raspppoe raspppoe.sys Sat Apr 11 00:46:30 2009 (49E020A6)
8c8ed000 8c901000 raspptp raspptp.sys Sat Jan 19 00:56:34 2008 (47919112)
8c901000 8c916000 rassstp rassstp.sys Sat Apr 11 00:46:40 2009 (49E020B0)
807b2000 807ee000 rdbss rdbss.sys Sat Apr 11 00:14:26 2009 (49E01922)
8ef1f000 8ef27000 RDPCDD RDPCDD.sys Sat Jan 19 01:01:08 2008 (47919224)
8ef27000 8ef2f000 rdpencdd rdpencdd.sys Sat Jan 19 01:01:09 2008 (47919225)
8cc97000 8cca5000 rimmptsk rimmptsk.sys Wed Nov 15 03:16:23 2006 (455ACCD7)
8cca5000 8ccb9000 rimsptsk rimsptsk.sys Tue Nov 14 22:42:45 2006 (455A8CB5)
8ccb9000 8cd0a000 rixdptsk rixdptsk.sys Tue Nov 14 20:35:19 2006 (455A6ED7)
8cc7d000 8cc97000 sdbus sdbus.sys Sat Apr 11 00:19:14 2009 (49E01A42)
8ef71000 8ef85000 smb smb.sys Sat Apr 11 00:45:22 2009 (49E02062)
88949000 88951000 spldr spldr.sys Thu Jun 21 20:29:17 2007 (467B17DD)
8cdb3000 8cdf4000 storport storport.sys Sat Apr 11 00:39:19 2009 (49E01EF7)
8ec0a000 8ec5d000 stwrt stwrt.sys Sat May 05 20:40:01 2007 (463D23E1)
8c926000 8c927380 swenum swenum.sys Sat Jan 19 00:49:20 2008 (47918F60)
88607000 886f1000 tcpip tcpip.sys Thu Feb 18 06:28:54 2010 (4B7D2476)
8cdf4000 8cdff000 TDI TDI.SYS Sat Jan 19 00:57:10 2008 (47919136)
8ef51000 8ef67000 tdx tdx.sys Sat Apr 11 00:45:56 2009 (49E02084)
8c916000 8c926000 termdd termdd.sys Sat Apr 11 00:51:14 2009 (49E021C2)
81cc0000 81cc9000 TSDDD TSDDD.dll Sat Jan 19 01:01:09 2008 (47919225)
889da000 889e3000 tunmp tunmp.sys Sat Jan 19 00:55:40 2008 (479190DC)
889cf000 889da000 tunnel tunnel.sys Thu Feb 18 06:28:13 2010 (4B7D244D)
8c95c000 8c969000 umbus umbus.sys Sat Jan 19 00:53:40 2008 (47919064)
8eee2000 8eee3700 USBD USBD.SYS Sat Jan 19 00:53:17 2008 (4791904D)
8c5ef000 8c5fe000 usbehci usbehci.sys Sat Apr 11 00:42:52 2009 (49E01FCC)
8c969000 8c99e000 usbhub usbhub.sys Sat Apr 11 00:43:14 2009 (49E01FE2)
82ba8000 82be6000 USBPORT USBPORT.SYS Sat Apr 11 00:42:55 2009 (49E01FCF)
8c5e4000 8c5ef000 usbuhci usbuhci.sys Sat Jan 19 00:53:20 2008 (47919050)
8eef2000 8eefe000 vga vga.sys Sat Jan 19 00:52:06 2008 (47919006)
8eefe000 8ef1f000 VIDEOPRT VIDEOPRT.SYS Sat Jan 19 00:52:10 2008 (4791900A)
82b23000 82b32000 volmgr volmgr.sys Sat Jan 19 00:49:51 2008 (47918F7F)
82b32000 82b7c000 volmgrx volmgrx.sys Sat Apr 11 00:39:25 2009 (49E01EFD)
88910000 88949000 volsnap volsnap.sys Sat Apr 11 00:39:37 2009 (49E01F09)
8c9e1000 8c9f4000 wanarp wanarp.sys Sat Jan 19 00:56:31 2008 (4791910F)
8c5d8000 8c5e4000 watchdog watchdog.sys Sat Apr 11 00:22:43 2009 (49E01B13)
82a00000 82a7c000 Wdf01000 Wdf01000.sys Sat Jan 19 00:52:21 2008 (47919015)
82a7c000 82a89000 WDFLDR WDFLDR.SYS Sat Jan 19 00:52:19 2008 (47919013)
81aa0000 81ca3000 win32k win32k.sys Sat May 01 10:13:35 2010 (4BDC370F)
8cd7b000 8cd84000 wmiacpi wmiacpi.sys Sat Jan 19 00:32:47 2008 (47918B7F)
82acf000 82ad8000 WMILIB WMILIB.SYS Sat Jan 19 00:53:08 2008 (47919044)
Unloaded modules:
889c2000 889cf000 crashdmp.sys
Timestamp: unavailable (00000000)
Checksum: 00000000
8870c000 887ca000 dump_iaStor.
Checksum: 00000000
8eee2000 8eeeb000 kbdhid.sys
Checksum: 00000000
