After booting up my laptop and reaching the desktop, the right click feature will stop immediately after starting up completely, and clicking on anything is a problem on it's own. The only way I have found to work around it is to Ctrl + Alt + Del and Switch User, then go to the power options and restart, as the conventional way of shutting down does not work.
I contacted my laptops manufacturer (ASUS) and they suggested that it could be a touchpad driver problem. So they emailed me the latest driver and I downloaded it. To my surprise, it actually worked..... for about 5 minutes. The right clicking problem still persisted.
So I looked into other forums and they suggested a problem with some Context Menu Handlers. I downloaded the suggested program 'ShellExView' and followed the instructions down to the letter on how to use it. Currently, as I'm typing this post, I have had to copy and paste patches of text because when the right click feature stops, the keyboard disengages, and the only workaround is the power button.
That didn't work at first, so I looked further into it, and it was also mentioned that some Property Sheet and Icon Handlers can be to blame. Currently, the only Property Sheet, Icon and Context Menu Handlers still enabled are the ones required for the laptop to boot up the OS. (shell32.dll's) This problem is still persisting, even with all these off.
The laptop is only 2 months old, and was bought off eBay (I know it sounds like the stupid thing to do, but I never thought I'd have this much heartache in two months..) It was fine, up until last week, when this problem started to occur. I have done a fresh format about 10 days ago, and even with nothing on the system other than ASUS Programs, the right click problem is still happening.
I'm about at my wits end with this dilemma, as not only have I lost valuable time sorting this out, I have grown to the point that I may have to sell it as defective.
If anyone has any clue as to what is going on with my system, I would oh-so very muchly appreciate the help.
Thanks in advance.
Thanks in advance.
- ASUS G50VT Gaming Notebook
- Core 2 Duo 2.13GHz
- ASUS PM45 Mobile Controller Hub
- 4GB DDR2-800 RAM Sticks (2 x 2GB)
- Graphics Card(s)
- nVidia GeForce 9800M GS
- Realtek High Definition Audio
- Primary - Laptop LCD Screen 15.4". Secondary: Acer AL1916W 19" Widescreen
- 1366 x 768 & 1440 x 900
- 1x ST9320421AS (320GB, SATA300)
- PSU
- 6 Cell Lithium Ion Battery (4.5 hrs on Battery Saving Mode)
- Case
- ASUS G50VT Case with RoG (Republic of Gamers) light on lid.
- Cooling
- Standard Laptop Cooling
- Integrated Laptop Keyboard (Synaptics TouchPad)
- Microsoft Cordless Mouse
- 50kbps - 200kbps.... (Mobile Broadband) :(
- Other Info
- The laptop is primarily used for 3D Gaming, but is also used for multimedia (Photoshop, Dreamweaver, Flash, etc.)
