second hard drive randomly goes missing?
oukanna
Heya, I have searched around the internet to try and solve my problem but have had no luck, hopefully someone here can help me. :)
I run a decent pc windows vista ultimate x64.
Also i have 2x 250gb Hard drives 1IDE and 1 Sata i believe.
Every now and then (usually when i leave it running on its own for a couple of hours)
my second hard drive just simply disappears from my computer, i cant seem to access it until i reboot my pc. It gets quite annoying because it does this sometimes when im working in Maya or photoshop so restarting is a pain. I am not sure why it does this; has anyone had the same problem??
I think you need to edit your power settings,
Control panel>classic view>power options>change plan settings>change advanced power settings expand hard disk and set turn off harddisk after policy to 10000 or more.
Post back the results :)
    Wipro
    Intel dq35j0
    8 Gb
    inter express chipset
    Realtek
    Wipro
    1024*768
    500 gb
    DELL
    Dell
    100 mbps(office lan)
Thankyou :) I have gone into the settings and changed the time to 1000 :D it was set at 20minutes....i had no idea Hard drives switched off after some time lol maybe this will help :) *fingers crossed*
good luck :)
    Wipro
    Intel dq35j0
    8 Gb
    Realtek
    Wipro
    1024*768
    500 gb
    DELL
    Dell
YES! Thank you this helps very much, I already my thouht my 500gb hard drive is gone :confused:
I registered only to say thank you lol :D
