It has been a while since the last blog posting, Windows 7 RTM – Go Get It, and we have a lot of catching up to do.
The Windows 7 GA data is still October 22nd, less than a month away, which means your application should be almost ready for Windows 7. As you prepare your applications for Window 7, be sure to verify that you don’t have any issues with version checking and UAC Data Redirection. This post topic, Session 0 Isolation, is another application compatibility topic that requires our special attention, especially if your applications include services. If your services are working on Windows Vista, most likely they will continue to work on Windows 7 (still you need to test your application fully on Windows 7). However, if you didn’t run the proper compatibility testing on Windows Vista, you might want to take few moments to read this post.
Let’s start with a better understanding of what services are.
What are services?
A service is an integral mechanism built into Microsoft Windows operating systems. You can think of services as “special applications” that run with no regard to the current user context. Services are different from “regular” user applications because you can configure a service to run from the time a system starts up (boots) until it shuts down, without requiring an active user to be present – that is, services can run without having any users logged on.
We like to think about services as running “tasks” for us in the background without interfering with user operations. Services on Windows are responsible for all kinds of background activity that do not involve the user, ranging from the Remote Procedure Call (RPC) service, through Printer Spoolers, to the Network Location Awareness service.
What’s the problem?
Some services may attempt to display user interface dialogs or communicate with user applications. Such functionality is “typical” of Windows XP services, mainly because it is easy to do so. If you happen to own a service that attempts to display some user interface objects, like a dialog box, or tries to communicate with applications you might run into trouble running on Windows 7.
When running a service that is trying to display a dialog box on Windows 7, instead of the desired dialog box, you will see an annoying flashing icon on the taskbar. And, if you press on that flashing icon, you will see a security dialog box. To be more specific, when running on Windows 7, your service may experiences one or more of the following symptoms. The service:
The Reason: Session 0 Isolation of Windows 7 Services
In Windows XP, Windows Server 2003, and earlier versions of the Windows operating system, services and applications run in the same session as the one started by the first user who logs onto the console. This session is called Session 0, and as shown in the following image, prior to Windows Vista, Session 0 included both services and standard user applications.
Running services and user applications together in Session 0 poses a security risk because services run with elevated privileges, while user applications run with user privileges (most of which are not admin).This makes the services targets for malicious agents that are looking for mechanisms to elevate their own privilege levels by “hijacking” the services.
Starting with Windows Vista, only services are hosted in Session 0. User applications are isolated from services, and run in subsequent sessions created when users log onto the system: Session 1 for the first logged on user, Session 2 for the second, and so on, as shown in the following image.
Entities (applications or services) running in different sessions cannot send each other messages, share UI elements, or share kernel objects without explicitly qualifying them to the global namespace and providing the appropriate access control settings. The following image illustrates this:
You can find additional valuable information about this in Impact of Session 0 Isolation on Services and Drivers in Windows Vista (http://www.microsoft.com/whdc/system/vista/services.mspx), an article that is equally applicable to Windows 7.
How can you detect whether your service might experience some of the above-mentioned problems?
So far, we have presented the symptoms associated with Session 0 isolation of Windows services, explained what service isolation is, and how it may affect your services and applications. Below are tests and other actions you can take in order to pinpoint your real problem and start resolving it.
Test #1 – Verifying service (or any other process) session assignment
The left image shows the process properties for the csrss.exe instance that runs at the high system integrity level (session 0), while the image on the right shows the process properties for the csrss.exe instance that runs with medium integrity level (session 1) of the current logged-in user (which is me).
If your service is running under Session 0 and under a high integrity level, it will be unable to display UI directly. It is also likely that you will experience problems when sharing kernel objects or files with the service.
Test #2 – Ensuring object accessibility
The following image displays an example of a shared object that only administrators and the SYSTEM group can access:
Now that you know what the problems could be, what about fixing them?
You've already done the hard part, knowing and understanding that you have a session 0 issue; solving these problems is easy.
Here are some ideas on how to solve the above mentioned problems:
You can find more-detailed information about this topic in the Windows 7 Training Kit for Developers, including a detailed whitepaper and hands-on-lab. If you want, you can download just the Session 0 Isolation hands-on-lab directly.
Here is some basic information about the tools used in this post:
Process Explorer – a monitoring tool for Windows processes that is able to display process integrity levels and object security information.
More...
What are services?
What’s the problem?
- Is running, but cannot do what it is supposed to do, and just eats CPU cycles and memory
- Is running, but other processes can't communicate with it and it cannot communicate with the user, or other applications / services
- Is trying to communicate with user applications through window messages, but the window messages are not reaching their destination
- Displays a flashing icon on the taskbar indicating the service wants to interact with the desktop
- The service fails to display a UI or it displays a mitigation UI (or annoying flashing dialog box): When a service attempts to show any user interface element (even if it is allowed to interact with the desktop), a mitigation layer prompts the user with the Interactive services dialog detection dialog box, as shown in the next image. The user may opt in to see the service UI on the session 0 secure desktop, but the interruption in workflow makes this a serious application compatibility issue. Furthermore, some users may not react very well to a dialog that blocks your services / application from getting the user input and breaking the flow of the application.
- Objects shared by services and applications become invisible or inaccessible: When an object created by a service is accessed by a standard application (running with standard user privileges), the object cannot be found in the global namespace (that is, it is private to session 0). This means that other applications will not be able to access the so-called “shared object” from the global namespace, and most certainly, not directly from session 0. Additionally, security changes might warrant a situation where even if the object is visible, it is not accessible. This may affect other processes (such as standard user applications) from interacting with your service, again breaking the application flow.
- Launch Process Explorer.
- To download or learn more about Process Explorer, see the Process Explorer Web site on Microsoft TechNet.
- Ensure that Process Explorer displays all processes:
- Click File.
- Choose Show processes from all users.
- Locate the first csrss.exe process, which is a service found under the System Idle Process (see next image), and inspect its properties:
- Right-click the process.
- Select Properties.
- Navigate to the Security tab.
- Note the session in which the service runs (typically Session 0) and its integrity level.
- Locate the second csrss.exe process, found under the Wininit.exe (see next image), and inspect its properties as you did in step #3:
- Click File.
- Locate the suspected service.
- If the service contains objects that you know are shared with user applications, inspect their handles in the Handles lower pane (press CTRL+H to see it, or access it from the View menu).
- Right-click each suspected handle and select Properties.
- Switch to the Security tab to see the users and groups that are allowed to access the object referenced by this handle.
- If a service needs to interact with the user by sending a message, use the WTSSendMessage function. It is almost identical in functionality to a MessageBox. This will provide an adequate and simple solution to services that do not require an elaborate UI, and is secure because the displayed message box cannot be used to take control of the underlying service.
- If your service requires a more elaborate UI, use the CreateProcessAsUser function to create a process in the requesting user’s desktop Note that you will still need to communicate between the newly created process and the original services, which is where the next bullet point kicks in.
- If two-way interaction is required, use Windows Communication Foundation (WCF), .NET remoting, named pipes, or any other interprocess communication (IPC) mechanism (excluding window messages) to communicate across sessions. The assumption is that because these technologies (most of them) integrate better security policies than the one used by basic Windows Messaging, they will provide the required elevation (if needed).
- Secure communication and other shared objects (for example, named pipe, file mapping), by using a Discretionary Access Control List (DACL) to tighten the set of users granted access to the mechanism. Use a System Access Control List (SACL) to ensure that medium- or low-integrity processes can access the mechanism even though a system- or high-integrity service created it.
- Ensure that kernel objects meant to be shared across sessions have names prefixed with the Global\ string, indicating that they belong in a session-global namespace.
- More information: http://technet.microsoft.com/en-us/sysinternals/bb896645.aspx
- Download: http://download.sysinternals.com/Files/ProcessExplorer.zip
You can get much more information about this topic and others in Windows 7 topic page on channel 9.
For more Windows 7 Technical content and hands-on experience download the - Windows 7 Training Kit for Developers is also a great place to learn more about this topic
More...
