Solved Sidebar - 2 monitors
SimonToddmUSIC
I run two monitors with my desktop "extended" over both.
All has been well with the Sidebar sitting pretty on my main monitor (which, incidentally is on the right-hand side on my desk).
However, I suddenly found, upon booting up one morning, that my settings had disappeared. I have reset them, but I now find that the Sidebar is sitting on my No#2 monitor, which effectively means that it is in the middle of my desktop, if you follow me.
This isn't a show-stopper for me, although I sometime don't switch the No#2 monitor on.
I'm trying to find a way to reposition the sidebar, as all I seem to be able to do is turn it on and off.
Any ideas good people?
Right click on the sidebar then select properties and there is a little drop to select the monitor ;)
    Windows 11 Workstation
    Ryzen 9 5950X
    Creative
    Drive
    1500W ThermalTake Toughpower
    ThermalTake Level 10 GT
    Enermax Liqtech 240
    Surface Ergonomic.
    Logitech Performance MX
    350 Mb/s
    WinTV NovaTD
    HP CP1515n Color Laser
    Microsoft LifeCam Cinema
    APC 750i Smart UPS
    windows 10
    Surface Pro 3
    Intel HD Graphics 4400
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
