N normanlobban New Member Nov 7, 2009 #1 I have been trying to delete/uninstall Spyware and it just wont. Help. My Computer System One
bassfisher6522 Member Nov 9, 2009 #2 Use MSE (micorsoft security essentials), that should clean it for you. My Computer System One Manufacturer/Model Self built CPU AMD Athlon 64x2 6000+ 3.0ghz Motherboard Asus M4N78 Pro Memory 3Gb PC2-5300 DDR2 @ 667mhz Graphics Card(s) XFX Radeon HD 4770 512mb GDDR5 Sound Card VIA HD Audio Monitor(s) Displays Dual monitors: HP W1907 LCD 19" and Gateway HD Display 19" LCD Screen Resolution 1440x900 Hard Drives Barracuda 7200.10 SATA 3.0Gb/s 320 x 2-GB Hard Drive PSU Antec Earthwatts 80 plus 500 watts Case Ultra E-Torque ATX Mid tower clear side w/2 120mm fans Cooling Thermaltake MaxOrb cpu cooler w/120 mm blue led Keyboard OEM HP Mouse OEM HP Internet Speed Download 6885 kb/s upload 367 kb/s Other Info Optical: Super Muliti DVD burner w/lightscribe, Hauppauge WinTV HVR-1800
M Mark Phelps Member Nov 10, 2009 #3 normanlobban said: I have been trying to delete/uninstall Spyware and it just wont. Help. Click to expand... Do you know what specific spyware? Both Avira and Kaspersky offer free, downloadable Antivurus ISO images -- which you then burn to CD, boot from, and can use to clean your installation. Since they run outside of Vista, they are safe from any present infections. My Computer System One Manufacturer/Model Home built CPU Athlon x64 4400 Motherboard ASUS A8n32-deluxe Memory OCZ 2GB low-latency 3200 Graphics Card(s) ATI X1600 Sound Card B-enspirer CMI8788 Monitor(s) Displays Samsung 24-inch flat panel Screen Resolution 19290x1280 Hard Drives WD 320GB SATA II PSU 350 watt enermax Case Antec PS180 Keyboard Logitech G15 gaming Mouse Logitech wireless Internet Speed Broadband -- 15MB
dinesh Vista Expert Vista Guru Nov 11, 2009 #4 Hi, you can use Anti virus program like ESET NOD32 Also, scan your computer using Malware Bytes Anti Malware. http://www.eset.com My Computer System One Manufacturer/Model Compaq CPU intel core 2 duo T 5550 @ 1.83 MHz Motherboard intel 965 chipset family Memory 2 GB DDR 2 SD RAM @ 667 MHz Graphics Card(s) On board upto 358 MB RAM Sound Card Onboard Monitor(s) Displays 15" Hard Drives 160 GB WDC
avgwarhawk Power User Nov 11, 2009 #5 Malwarebytes will do the trick for you. My Computer System One Manufacturer/Model Cyberpower CPU AMD Phenom X4 9850 Motherboard MSI K9N SLI V2 Memory 8 GIG DDR 800 Graphics Card(s) EVGA 9800 GT 512mb Sound Card onboard Monitor(s) Displays SyncMaster 220wm Screen Resolution 1680x1050 Hard Drives Hitachi something or other 500 gigs PSU 650 watts
