System.ini problems
I looked for it under my username and I didnt find the desktop.ini file. Don't know if its supposed to be ther or not. Oh and I checked the documents folders, the empty one says that the size is 282 bytes, Size on disk 4.00 KB, and that it contains 1 files, 0 Folders. and in location it says C:\Windows\System32\config\systemprofile where the one with my files says C:\Users\Eddie Silver. This is looking under Properties BTW. Dunno if it helps any in solving the problem tho.
    ACER Aspire
    Intel Dual core 1.6 Ghz
    2 GB DDR2
    Nvidia 9500GT 512Mb PCIE 2.0
    1.5 MB
I just uninstalled itunes and reinstalled it to see if it solved the itunes problem but the same message of not having enough access privileges appeared so im guessing whatever the problem with the duplicate folders is also the cause of that.
    ACER Aspire
    2 GB DDR2
    1.5 MB
Does my post about the properties for the folders give anyone ideas as to the problem?
    ACER Aspire
    2 GB DDR2
    1.5 MB
I've been having all the same problems. I can't open Firefox without right-clicking and choosing "Run as administrator" even though I'm the only user on this computer.
iTunes won't open either no matter what I do. I tried disabling the Sidebar but it's already disabled and I can't even bring it back up!
This all started happening after I installed Vista SP1 yesterday (10/27/09). Any help? It seems like the comp thinks I'm not an admin.
    Acer Extensa 4620Z
    1.47 Ghz Intel Pentium Dual Core
    Acer Biwa Rev
    2038 Mbs
    Mobile Intel 965 Express Chipset
    RealTek High Definition Audio
    Laptop 15.4" LCD
    WDC WD3200BEVT-22ZCT0 [Hard drive] (320.07 GB)
    Broadband
