I entered restart on my system and then computer screen displayed 'Shutting Down'. It just sat there and would not finish shutting down and restarting like I requested. Does anyone know what causes this? I had to pull the wall plug to shut the pc see off. There wasn't any access to the keys and the power off buttton would not work when the screen was displaying 'Shutting Down'. I waited 40 minutes before pulling the plug just in case the system was going to eventually restart.
I am adding a little more information that may help in providing a solution to my problem.
On 11/18/12 after I discovered the restart hanging problem, I tried another restart after I pulled the plug and powered up again. The second restart worked normally (the system did not hang in the 'Sutting Down' screen). After a couple of hours of PC use, I tried a third restart and it worked normal. I did not shut the PC down when I finished using it on 11/18/12. On 11/19/12 after I clicked the mouse to wakeup the system from it's sleep mode, I proceeded to read e-mails, then I read a few news articles on the Google news site. I attempted a restart just to see what would happen. The system hung again just like it did on 11/18/12. The system just sat there displaying the 'Shutting Down' screen. After I pulled the wall plug to 'kill' the system, I plugged it back in, powered up and used it for about 10 minutes. I tried a restart to see what would happen and the restart worked normally with no problems. I also ran security scans that all came back normal. So sometimes the restart works and sometimes it doesn't work. What would cause this? What will fix this?
