Heyy!
Ive been having this problem for about a week and its just popped out of nowhere!
So whats happening is that when the system boots it all loads fine, but when the taskbar comes up i cant click on any of my quick launch icons, programs minimised, only the start orb.
The only way to stop this i have found is to end the process "Explorer.exe" in Task Manager then start the process again and its getting a bit annoying.
thanks for any help!
Daniel =)
Daniel =)
- Custom built.
- AMD FX-4170 Quad-Core @ 4.2GHz
- ASUS M5A78L-M/USB3
- 8GB DDR3 @ 1333MHz
- Graphics Card(s)
- Nvidia geforce GTS240 1GB, 3GB shared memory. SLI soon.
- realtek high definition audio, onboard.
- 19 inch widescreen monitor, DVI.
- 1440 by 900, 32 bit colour, 75 hertz.
- 1 128GB Kingston SSD Now OS drive
1 250GB sata main drive.
1 160GB from old install.
1 500GB for re-directs from OS disk.
1 Seagate GoFlex External 1TB with backups.
- PSU
- 750 watt.
- Case
- Foxconn TSAA699.
- Cooling
- 4 fans.
- Trust Wireless Optical Deskset Keyboard.
- Trust Wireless Optical Deskset Mouse.
- download about 60/65MB/s, upload about 3/4MB/s. Virgin Media
- Other Info
- ASUS EEEPad Transformer 16GB with Dock w/32GB class10 SD |
Dell PE1950 II / 2xDual Core Xeons @3.00GHz / 16GB RAM / PERC 5i/R / 2x36GB SAS OS - 2x1TB SATA Data both RAID 1 |
