I notice that some months ago a request for details of a Vista driver for this printer was posted.
The original drivers as supplied should work OK on Vista, but I have also downloaded the ZIP file (right at the bottom of the page under Installation CDs) at
TDK-Media Europe | Download
How to do it.
Follow the above link and unzip to hard drive. Run the setup file in folder "SETUP" then, after the software installation is complete plug in the printer. Vista will search unsuccessfully then ask what to do. Point it at the "DRIVERS" folder and the required driver will be installed. Printer should then work OK. Suggest you copy all the files contained in the ZIP file to a CD for safe keeping.
Hope this helps.
How to do it.
Hope this helps.
