Thumbnail Previews - Change Border
How to Change the Border for Thumbnail Previews in Vista
This will show you how to change the border for all Windows Explorer thumbnail preview images in Vista to either have a drop shadow, photo, video sprockets, or no border.
You will need to click on View or Views, on Windows Explorer window Menu bar, and have it set to either Medium Icons, Large Icons, or Extra Large Icons to see a thumbnail preview of the file image as the icon.
EXAMPLE: Available Thumbnail Preview Image Borders
NOTE:
The default border for thumbnails in Windows Explorer is the Photo_Border-2 image below.
OPTION ONE
To Use a REG File Download
1. For No Border
No_Border-0.reg
download
B) Go to step 5.​
2. For a Drop Shadow Border
Drop_Shadow-1.reg
download
B) Go to step 5.​
3. For a Photo Shadow Border
Photo_Border-2.reg
download
B) Go to step 5.​
4. For a Video Sprockets Border -
Video_Sprockets-3.reg
download
5. Click on Save, and save the .reg file to the Desktop.​
6. Right click on the downloaded .reg file and click on Merge.​
7. Click on Run, Continue (UAC), Yes, and then OK when prompted.​
8. When done, you can delete the downloaded .reg file if you like.​
9. You may need to refresh (F5) the window or desktop to see the border change.​
OPTION TWO
Through Registry Editor
1. Open the Start Menu.​
3. If prompted by UAC, then click on Continue.​
4. In regedit, navigate to the locaton below. (See screenshot below)​
HKEY_CLASSES_ROOT\SystemFileAssociations\image
5. In the right pane of the registry, right click on Treatment and click on Modify. (See screenshot above)​
6. Type in the value data number in the table below for the border that you want for all Windows Explorer thumbnail images to have, then click on OK. (See screenshot below table)​
See the example at the top of the tutorial to see what each border looks like.
Number
Border
0
No Border
1
Drop Shadow
2
3
Video Sprockets
7. Close regedit.​
8. You may need to refresh (F5) the window or desktop to see the border change.​
  • No_Border-0.reg
  • Drop_Shadow-1.reg
  • Photo_Border-2.reg
  • Video_Sprockets-3.reg
Neat one Shawn, I never knew you could do this.
    Airbot 2.0
    EVGA Nvidia GTX 480 -Fermi
    ASUS Xonar D2X
    1920x1080@60hz
    1 OCZ Vertex2 180GB SSD
    Pioneer DVD Burner DVR-S18M
    Corsair HX1000W
    Cooler Master HAF 932
    Logitech Wireless MK700
    Windows 7
    W.E.I final score= 7.7
    Windows Vista=5.9
Neither did I. It was a nice surprise when I stumbled across it. :)
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
This is koooooool :)
I'm surfing this tut from time to time cause I always find something I haven't stumble on yet. I'm also trying to find hacks here and there.
Peace
Ghis
