Hi, a couple more thoughts and bits and pieces I've scavenged:
First - a rational list of some causes of black screen with blinking cursor
Computer Boots to Black Screen with Blinking Cursor | Computer Tips
- note 'some' causes, as you'll appreciate.
Second: DELL Vista specific
Computer Does Not Boot to Microsoft Windows Vista | Dell
Step 1, Step 3?
Third: BIOS beep? I guess you'd have mentioned it if there was such. I doubt this occurs somehow.
Fourth:
Using a Fn key, (like F8 for safe mode, F10 for BIOS etc), check your boot options with and without the problem present. (I can't remember 'n' and the text telling me what the options are disappears.. guess what.. too quickly.
I get sthg like:
\Windows\system32\winload.exe
Partition 1
Hard disk (parameter)
[ /Noexecute=optout /noGuiBoot /Bootlogo
Check this is unchanged.
Fifth: Try repairing the boot record rather than doing a System Restore.
Repairing the boot record.
How to use the Bootrec.exe tool in the Windows Recovery Environment to troubleshoot and repair startup issues in Windows
Windows 7 Directions: ('cos I guess Vista will be similar- check)
1. Boot from the Windows 7 DVD.
2. Select Repair my computer.
3. Select Command Prompt
4. From the command prompt enter the following command: Chkdsk /R C: where “C” is your boot drive.
5. Answer Y to check the disk the next time that the system restarts.
6. Reboot the system. After the reboot, Windows will check the hard disk and try to repair the damaged area.
7. If you still get the error after this process, repeat the process but try rebuilding the master boot record at the command prompt with the following command: bootrec /fixboot and then rebooting
If your system can be saved, you should now be able to boot back into Windows without a problem!
Now all the above can only give you clues. It won't tell you why sthg's going wrong.
(& I'm betting Windows hasn't started booting when you get the flashing cursor, so the event log (BSOD etc etc) won't capture your error message).
Step 1, Step 3?
Fourth:
I get sthg like:
Partition 1
- AMD Athlon X2
- 3Gb
- 500Gb 7200RPM
- Other Info
- Laptop HPG60
