Vista Won't Read DVD Burned in XP
trumpet205
Hi there,
I have burned many DVD (data) on my XP before I switch a computer. Now that I have a Vista x64, the CD drive won't read them. If I use ISOBuster I can see the track and extract them. But if I use Windows Explorer it will prompt me to "prepare blank disc"! Any help? I already finalize the disc and confimred it. Do a hardware diagnostic check and turns out nothing went wrong.
By the way, how can I make Vista not look for application if I insert other CD. (By that I mean just open the CD rather than look for autoplay, I already disable autoplay.)
CD Drive - TSSTCorp H653Q
OS - Vista Home Premium x64
System - HP Pavillion s3600z
    HP Pavilion Slimline s3600z
    AMD Athlon Dual Core 4450e
    3GB
    Nvidia 9300M GS 256MB
    HP w1907
    1440 x 900
It could be the brand of disc that your Vista machine doesn't like. I had to change brands when I got my Vista, the CD's I used on my XP and WinME machine would read but I couldn't write to them in Vista.
Try another brand and see if that makes a difference, that's all I can offer in the way of help ;)
    Windows 10 Home
    HP 8312 (Socket FP4)
    Microsoft Optical Wheel Mouse
    62.86Mbps down 18.19Mbps up
Good advice though Joan.
    Scratch Built
    Intel Quad Core 6600
    Asus P5B
    4096 MB Xtreme-Dark 800mhz
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Microsoft
    Targus
    1500kbs
    Self built.
I'm using HP Desktop. And I use combination of HP and Sony DVD. Both which did not work.
By the way. all DVD are in UDF 1.02
    3GB
    HP w1907
    1440 x 900
Vista supports Read & write UDF 1.02, 1.50, 2.0x, 2.50, (Read) 2.60 natively. Despite all programs 'conforming to standard' in the past incompatibilities have been reported with cdrw written by InCd, directCD and B'sclip and Roxio. This may help.
Is this a new system. What brand of DVD Reader/Writer do you have?
    Scratch Built
    Asus P5B
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Microsoft
    Targus
    1500kbs
    Self built.
Although Vista provides UDF 1.02, it does not provide ISO-9660, which it ought to do to enable the DVD to run under some versions of Windows Media Player. Such DVDs will run in Cyberlink PowerDVD, which is often supplied with computers or editing software. You could also look here :-
Why Won't my DVD Play?
    Scratch Built
    Asus P5B
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Microsoft
    Targus
    1500kbs
    Self built.
As mentioned above, this is a new PC. Most DVD are written by InfraRecorder
DVD Drive - TSSTCorp TS-H653Q
Linux on the same system can perfectly read those disc.
    3GB
    HP w1907
    1440 x 900
    Scratch Built
    Asus P5B
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Microsoft
    Targus
    1500kbs
    Self built.
