Wireless issue
charl111
Hi everyone,
Hopefully someone can help me. I recently re-installed Vista onto my Samsung laptop due to a problem, however today after updating the drivers etc, when I try to connect to my wireless it won't access the internet. It finds the wireless, connects but no internet. However, it will access the internet when the security is open, but when it's secured via wap, wpa2 etc, no chance. It says 'unidentified network, local access only'. My other laptop connects no problem, I have updated the Netgear firmware etc.
Thanks in advance :)
Your computer connected just fine before the reinstall, right? Try connecting it via and actually Ethernet cable instead of over wifi and tell me if that works.
Also, how old is your computer?
    Dell Inspiron 1545
    Intel Core 2 Duo T6400 @ 2.00 GHz
    DELL - 27d90219 Phoenix ROM BIOS PLUS Version 1.10 A05
    Generic PnP Monitor (DPMS), 15.3" (34cm x 19cm)
    1366x768
    Internal 320 GB
    Portable 320 GB used for separate storage of media, plugged into USB port as needed.
    Single built in fan
    Built in
    Touchpad, + Logitech wireless mouse (USB)
    ~150 kilobytes/sec DL
    Usually have low HD free space left (<10 GB), often left on overnight. I really push its capabilities.
