I am running WordPerfect x4 (WP 14) in Vista Home Premium 64-bit. It works, but there are long (45 seconds or so) delays when opening or closing a file. It can take up to one minute for the printer to respond to a command and start printing. When I open WP, it takes 30 seconds or so for the program to go into the default font (it opens with the basic, WP default font and takes that long to switch to the font I have set as the default.)
I have heard that if you are having trouble with a program in Vista, you should right click on the program icon and select Run as Administrator, opening the program in that fashion.
I have two problems. The first is the one described above, with getting my version of WP to run smoothly and quickly in Vista. The second one is, when I try to right click on the WP program icon, the menu that comes up does not contain Run as Administrator as an option.
Just for kicks, I right clicked on every other shortcut on my desk top - every one of them allows Run as Administrator as an option. Not WP.
What is up with that? How can I run WP "as administrator"? And will that fix my general problem with WP? If not, what will?
- HP Pavilion
- AND Phenom(tm) II x 4 910 Processor
- 2.00 GB
- Graphics Card(s)
- ATI Radeon HD 4350
- Realtek High Definiition Audio
- 800x600
- 917.54 GB
- HID Keyboard Device (Standard Keyboard)
- Microsoft USV IntelliMouse Optical
