Context Menu - Take Ownership
How to Add Take Ownership to the Context Menu in Vista
This will add Take Ownership to the Context (right click) menu for all folders, files, and drives in Vista and Windows 7.
Application files, (EX: EXE, CMD, MSI) will still have Run as administrator instead of Take Ownership in the context menu.
When you use take ownership on a folder, it will take ownership of all the files and subfolders inside the folder to.
This Take Ownership context menu item needs to be used while logged on to an administrator account for it work.
EXAMPLE: Before and After Context Menus
STEP ONE
Add or Remove Take Ownership
1. To Add Take Ownership
Add_Take_Ownership.reg
download
B) Go to step 3.​
2. To Remove Take Ownership
Remove_Take_Ownership.reg
download
5. Click on Run, Continue (UAC-Vista) or Yes (UAC-Windows 7), Yes, and OK when prompted.​
After you have taking ownership of the file, you may still need to "Allow" your user account "Full Control" of the file before you will have full permission to access it. See steps 11 to 22 in the tutorial below for how.
STEP TWO
How to Use Take Ownership
1. Right click on a folder, file, or drive.​
NOTE: When you use Take Ownership on a folder, it will take ownership of all the files and subfolders within that folder to.​
Do not take ownership of the drive that you have Windows installed on. If you do, you will end up having to reinstall Windows.
2. Click on Take Ownership. (See Example at top)​
4. You will see a command window pop-up and then go away when it's finished. (See example screenshot below)​
5. The folder or file has been taken ownership of.​
NOTE:
A) You can verify from METHOD TWO step 7 here: How to Take Ownership of a Item in Vista
B) It will have your user name listed as the owner.​
  • Add_Take_Ownership.reg
  • Remove_Take_Ownership.reg
Your welcome Not liking Vista.
Welcome to the forum. :party:
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
Hi Salpap,
Yeah, this can come in handy if you need to take ownership alot, or need to take ownership of a bunch of sub folders and files.
Does this work for individual files, or just folders?
Example.....I have a back-up (file) of my favorites on a CD/RW disk, and when I wanted to overwrite it with a more recent version, Vista wouldn't let me do it, even with Admin privs.
    Q9550
    EVGA 790i Ultra
    4 gigs Patriot Viper EP @ 1600mhz
    EVGA GTX 280
    X-Fi Fatality Pro
    Samsung 2493 24"
    1900 x 1200
    WD 640g SATA 3.0 16 AAKS
    PC Power & Cooling Silencer 750w Quad SLI
    Antec 900
    Asus Silent Knight 2 CPU
    Saitek Eclipse 2
    Logitech G5 Laser
    Now @ 15mps down
Hi Clark,
It works for either one. ;)
Hi Clark,
I'm trying to run an application, and have tried all that I can think of to get permission for it to run a dll, but it continues to tell me I don't have permission. It's my machine, for crying out loud. I'm supposed to not have to ask for permission.
Anyway, I tried the "takeownership" thing, and it tells me I have ownership. When I look at the permissions, it says I have full acess, yet I still can't run the dll.
This is not a system file or directory, it's just a graphics program by Ogre.
Why can't I get permission? This is confusing!
Thanks for any feedback.
Hi Thales,
Is the program by Ogre compatible with Vista?
You may need to right click the program and use "Run as Administrator" on it to open the .dll file.
Hi Thales,
Thanks, Shawn.
"Run as Adminstrator" did the trick!
Great!
Your welcome Thales. Glad to hear that it worked for you. You can check the Run this program as an administrator box in Compatibility mode so you do not have to right click on the Ogre program everytime you want to open it. You can see how here if needed in step 7.
http://www.vistax64.com/tutorials/75909-compatibility-mode.html
Your welcome taco-man, and welcome to Vista Forums. :party:
I'm glad to hear that it was helpful to you.
For those who don't want the trick on the context menu and find a bit complicated the way to do it manually, they can do it this way:
Copy those 2 lines in notepad and save as for example: takeownership.cmd
Put the file in your windows directory.
takeown /f %1 /r
icacls %1 /grant yourusername:F /t
Now when you want to take ownership of a file or folder, run the command prompt as administrator and type in:
takeownership C:\folder for which you want to take ownership (or file)
If the entry is a folder, you will have ownership on all files within the folder.
This was fantastic, thanks a lot for this!
    Intel E8400 CPU
    Asus P5N-D
    4gb (2 x 2gb) DDR2
    Gigabyte 1gb 9800GX2
    Sound Blaster F4tal1ty
    Samsung 22" LCD
    1680 x 1050
    1 x 150gb Raptor SATA-2
    2 x 750gb Western Digital SATA-2
    730w Antec TruePower
    CoolerMaster CM690
    Logitech G15
    Logitech G9 Laser Mouse
Your welcome Admles, and welcome to Vista Forums. :party:
Hi Bukavu,
What is the name and location of the file that you are trying to delete?
The file may be in use. You might try booting into Safe Mode and see if you can delete it from there. This tutorial will show you how to boot into Safe Mode if needed.
http://www.vistax64.com/tutorials/123496-safe-mode.html
