Low Disk Space Warning in Vista
How to Disable or Enable Low Disk Space Warning in Windows
When your media device gets low on space, Vista will give you a Low Disk Space warning. This is to warn you to either clear space or get a bigger storage device soon.
This will show you how to enable or disable the Low Disk Space Warning for all drives in Vista.
Low Disk Space warning is enabled by default.
You must be logged in as an administrator to be able to do the steps in this tutorial.
  • This is not the same as the XP way.
  • This will not work on a protected OEM recovery partition.
You could lose data, possibly everything, on the hard drive if you run out of space on it. I would recommend backing up your data and getting a bigger hard drive soon, or make more room on the drive by uninstalling stuff you do not need anymore.
This is not the same as a Low Memory error. A Low Memory error is usually due to the page file being turned off, or it's Min and Max size set to low.
METHOD ONE
By Removing the Drive Letter
NOTE: This option only affects the single hard drive. By removing or hiding the hard drive letter, there will be no drive letter associated to this partition or drive. Vista will no longer see the partition as anything useful to it and will stop giving you the Low Disk Space warning for only this partition or drive.
METHOD TWO
Manually in Registry Editor
NOTE: This will disable or enable the Low Disk Space warning for all drives.
1. Open the Start Menu.​
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Search\Gather
5. In the right pane, double click on LowDiskMinimumMBytes to modify it, and do step 6 or 7 below for what you want to do. (See screenshot above)​
6. To Disable the Low Disk Space Warning
A) Type 0 (number), click on OK, and go to step 8 below. (See screenshot below step 7A)​
7. To Enable the Low Disk Space Warning
NOTE: This is the default setting.​
A) Type c8 (Vista) or 1 (Windows 7/8), click on OK, and go to step 8 below. (See screenshot below)​
8. In regedit, go to: (See screenshot below step 10)​
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Search\Gathering Manager
9. In the left pane, click on Gathering Manager to highlight in blue.​
10. You will need to take ownership of Gathering Manager and "Allow" your user account "Full control" of it before continuing.​
11. In the right pane of Gathering Manager, double click on BackOffLowDiskThresholdMB to modify it, and do step 12 or 13 below for what you want to do.. (See screenshot above)​
12. To Disable the Low Disk Space Warning
A) Make it empty, and click on OK. (See screenshot below step 13A)​
B) In regedit, go to: (See screenshot below)​
NOTE: If the Explorer key is not there, then right click on the Policies key in the left pane, click on New and Key, type Explorer, and press Enter.​
C) In the right pane of Explorer, double click on NoLowDiskSpaceChecks to modify it. (see screenshots below)​
NOTE: If the NoLowDiskSpaceChecks DWORD is not there, then right click on an empty space in the right pane, click on New and DWORD (32-bit) value, type NoLowDiskSpaceChecks, and press Enter.​
13. To Enable the Low Disk Space Warning
A) Type c8 (Vista) or 258 (Windows 7/8), and click on OK. (See screenshot below)​
B) In regedit, go to: (See screenshot below step 12C)​
C) In the right pane, double click on NoLowDiskSpaceChecks to modify it.​
D) Type 0 (number) and click on OK. (See screenshot above)​
14. When finished. close regedit.​
Needed this,thnx :)
    Intel
    Nvidia 9650M GT
    Asus N80VN-X1 Laptop
    1280 X 800
    1 X 250GB 5200 RPM
    11 MBPS
Path?
Greetings,
Hmmm........I don't have the Explorer sub-entry at the end of this path.
It ends at 'Policies'.
( HKey_Current_User\Software\Microsoft\Windows\CurrentVersion\Policies )
Any ideas?
Thanks
    Q9550
    EVGA 790i Ultra
    4 gigs Patriot Viper EP @ 1600mhz
    EVGA GTX 280
    X-Fi Fatality Pro
    Samsung 2493 24"
    1900 x 1200
    WD 640g SATA 3.0 16 AAKS
    PC Power & Cooling Silencer 750w Quad SLI
    Antec 900
    Asus Silent Knight 2 CPU
    Saitek Eclipse 2
    Logitech G5 Laser
    Now @ 15mps down
Greetings,
Any ideas?
Thanks
Hi Clark,
Did you click the arrow on the left side of Policies? (see circled in red below)
Otherwise, you could right click on Policies and click New > Key and then type Explorer and press enter. Then add the above to it.
Here's the data for the Binary (see below)
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
Shawn.........to clarify, there is no arrow next to 'Policies'. I found that a bit strange.
But..........I can create the 'Explorer' sub-folder?
Also.......do I also need to create both entries? (NoDriveTypeAutoRun & NoLowDiskSpaceChecks)
    Q9550
    EVGA 790i Ultra
    EVGA GTX 280
    X-Fi Fatality Pro
    Samsung 2493 24"
    1900 x 1200
    Antec 900
    Saitek Eclipse 2
    Logitech G5 Laser
    Now @ 15mps down
Hi Clark,
I'll do one better for you. I exported mine for you to merge with yours.
Here's how to do it:
1. Click on Policies.reg (below) and save it to your desktop.
NOTE: For 32 bit or 64 bit Vista.
View attachment Policies.reg
2. Right click on Policies.reg (on desktop) and click Merge.
3. Answer YES and OK to the confirmation pop-up windows.
4. Delete file when done.
That's it. It should be there now as above.
Hope this helps you,
Re: Low Disk Warning
Hi ShocWave,
Which part is not working?
What kind of hard drive are your using? (ATA/SATA, Raid, etc.)
I'm using just a regular ATA drive.
Even after I change the values the registry, the low disk space warning still comes up in my systray.
Hi Shocwave,
Make sure you do all of the above.
Also, do a restart to see if the changes will take affect then.
Let me know please, so I can update this tip.
Okay, it works now.
I remember seeing that method for Windows XP, but it didn't work for me, so I removed the changes to the registry.
It turns out you need a combination of both to get arid of those annoying messages.
SkocWave,
Glad to hear. I'll update this post.
Thank you for the feedback,
Updated.
I wanted to know if this reg download (the download itself) will work on a Vista 32 bit machine (realizing the name of the forum is VistaX64.com).
I just wanted to confirm that before downloading it.
Thanks,
Rich
Hi Rich,
This tutorial does not have a REG download. :confused:
However, unless the downloads here specifies different, they are all usually for both the 32 bit and 64 bit Vista. In that case, you will have two separate downloads for each version.
Hi Clark,
1. Click on Policies.reg (below) and save to your desktop.
Shawn,
On page one, there is a posting by you that has a reg file as an attachment (Policies.reg). I was curious if that file (I thought you made) will work on Vista 32?
Thanks,
Rich
Oh, ok Rich. Yes, it will work on the 32 bit or 64 bit Vista.
Shawn,
I used your registry file. Unfortunately I sent it to a client without testing it & they are having issues (including a quickbook registry error).
How do I undo everything except the low disk notification?
Here is the information from your file:
I now have the start menu items missing. Can I rerun this registry entry changing your entry:
Code:
"NoStartMenuMFUprogramsList"=dword:00000001
to :
Code:
"NoStartMenuMFUprogramsList"=dword:00000000
(Assuming 0 turns that off)?
Can I also reenable the autorun?
Code:
"NoDriveTypeAutoRun"=hex:91,00,00,00
Code:
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies]
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer]
"NoLowDiskSpaceChecks"=dword:00000001
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Network]
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System]
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Windows]
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Windows\Sidebar]
Rich,
This will undo that reg file:
Code:
"NoDriveTypeAutoRun"=dword:00000091
"NoLowDiskSpaceChecks"=-
"NoStartMenuMFUprogramsList"=-
OR
View attachment Policies.reg < Click to Download
Shawn,
Thanks for getting back to me so quickly.
1. Will that reg file undo everything (including the disk space notification)?
2. If so, & I want to stop the low disk notification would I do the following:
Code:
Thanks,
Rich
