Start Menu - Customize
How to Customize the Start Menu in Vista
This will show you how to set and use the Customize options for both the Normal and Classic Start menu. These will allow you to customize how links, buttons on the right side, icons, and menus look and behave in the selected Start menu.
EXAMPLE: The Normal Start Menu and Classic Start Menu
OPTION ONE
How to Customize the Normal Default Start Menu
1. Right click the Start button and click on Properties. (See screenshot below)​
2. Click on the Customize button. (See screenshot below)​
3. Select the options you want. (See screenshot below)​
  • The Top section - Allows you to select the buttons and how they open on the dark right side of the Start menu. You can also customize how icons and menus appear in the Start menu.
  • Start Menu Size - Allows you to change how many recent programs will be displayed in the white left side of the Start menu.
    NOTE: For more, see:How to Use the Recent Items List in Vista
  • Show on Start Menu - Choose if you want a Internet or E-mail shortcut displayed on the Start Menu. You can click on the drop down menu by each one to select which program you want to use for each if you have more than one installed.
    NOTE: If the Internet Explorer or Windows Mail option is grayed out, then this just means that they are not set as the default program.
4. Click on OK when done.​
5. Click on OK. (See screenshot below step 2)​
OPTION TWO
How to Customize the Classic Start Menu
1. Right click on the Start button and click on Properties. (See screenshot below)​
A) Add, Remove, Advanced, Sort buttons - Allows you to add or remove items from the Classic Start Menu.​
B) Clear button - Clears the recently opened documents, programs, and web sites. These are not displayed in the Classic Start menu.​
C) Advanced Start Menu Options - Allows you to select the buttons and how they open on the dark right side of the Start menu. You can also customize how icons and menus appear in the Start menu.​
5. Click on OK. (See screenshot for step 2 above)​
how do u add programs to the list of the ones that appear on the upper right side of the normal vista start menu? for example if i wanted to put downloads on that list how do i do it?
    AMD Athlon 64 3700+ 2.20 GHz
    Biostar GeForce 6100-M9
    2046 MB
    nVidia GeForce 7600 GT
    120 GB Seagate
Hi Scissormetimbers,
You cannot add anything that is not already in the list in Option One above. :(
For Downloads, you can:
1. Dot Personal folder with Display as a menu in Option One. From there you can select Downloads.
2. Pin the Downloads folder to the Start menu (left side). This tutorial will show you how to enable pinning folders.
http://www.vistax64.com/tutorials/98613-start-menu-pin-folder.html
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
ok thanks for the help shawn
    2046 MB
    120 GB Seagate
You're welcome Scissormetimbers.
Hi Shawn, I like the start menu as below, and can you show me where is this topic or can you write a topic about this (Customize that area).
Thanks
Hi, molie, I notice your using XP 32-bit, you do realise this is a forum geared towards vista 64-bit?
    Self built
    Intel E8400 3GHz
    Intel DX48BT2
    Kingston PC3-10666 4Gb
    XFX 9800 GTX XXX
    Soundblaster X-Fi XtremeMusic
    2x Samsung SM-T220HD 22"
    1680x1050 on two monitors
    WD Raptor X/150Gb in RAID0
    WD Raptor 36gb
    3x Samsung F1 1Tb
    Thermaltake ToughPower 850w
    Thermaltake Armor
    Tuniq Tower 120
    Dell Multimedia Enhanced USB
    Razer Diamondback 3G
    Thermaltake Muse esata caddy
Hi Molie, and welcome to Vista Forums.
Unfortunately you can only add or remove the buttons, on the dark right side of the Start Menu, that are listed in the Customize window in the screenshot below Option One step 4. The only way you can customize it further is to use some 3rd party program like Stardock WindowBlinds.
Stardock.com - Your Edge In Software
Sorry, :(
Hello! Mod...I am not sure if this question I'm about to ask belongs in this thread. Feel free to move it to the proper place if needed.
How can I add a program shortcut to the Accessories from the Startup Menu?
Thanks for any reply.
You're welcome Bennys.
Hi Shawn. Great work with these tutorials. I've just reinstalled Vista after neglecting it for a long time and I'm looking for tweaks. I'll be reading around most of the day I'm sure. :geek:
One thing that really bugs me is that I cannot figure out how to keep the dark menu and still change the Windows color from that very pretty but not to manly blue. ;)
Got a tweak or an app that can do that? I may be missing it too, if its buried somewhere else.
Thanks man, keep up the great work.
Hello TeMerc,
There is no way in Vista by default, but you might see if the free program Vista Start Menu may have the option to let you. I cannot remember if it allows you to customize the color or not, but it does have a ton of customizable features.
Hello TeMerc,
Thanks Shawn for the prompt reply.
I use Dennis's Tidy Start Menu already, so I'm guessing I may have found that eventually.
TeMerc
Yup, that did the trick. While it's not exactly the same color as the orig Vista dark, I can use the old Windows styles, change all my window colors and have the menu much better.
And it's got loads of other great features too. Best of all, I like so far is you can make the menu pop up anywhere you want it! :geek:
Thanks again!
Tom :cool:
You're welcome Tom. I'm happy to hear that it was able to do what you wanted.
Hi Brink,
Just wanted to say thanks for this tutorial! A not-so-good-with-computers friend of mine found this very useful after I sent her a link to it about three months back (just came across it here again and thought I should thank you). Very clear and easy to understand.
She told me a few days ago that she will be getting Windows 7 next week :shock: - while I'm stuck on Vista for now :(...
    Dell Inspiron 1720
    Intel Core Duo Processor T8300
    3072MB Dual Channel
    NVIDIA GeForce 8600M GT
You're most welcome Witch-King-of-Angmar. I'm happy to hear that it was able to help. :)
