Laptop on battery or just plugged to electricity
  1.    03 Apr 2016 #1
    Vista x64
    Local Time: 21:11
    I have a laptop I m using it like a desktop I was wondering should i use it without battery by electric only ?
    here its link of my laptop if it helps
    PS: I m using my laptop with europe plug since I live in europe I m using another plug to plug it plugger
  2.    03 Apr 2016 #2
    Fairfield County, CT
    Windows 7 SP1 x64
    Local Time: 23:11
    usa us connecticut
    Re: Laptop on battery or just plugged to electricity
    I have read that it is best to let it run on battery now and then and recharge when 2/3 used. If you just keep it plugged in, actually no problem. The battery will just die sooner, but no matter to you, since you have it plugged in.
  3.    05 Apr 2016 #3
    New Zealand
    Vista Home Premium 32bit.SP2
    Local Time: 16:11
    newzealand
    I did that with my last laptop and used the battery as a power supply if the power went off (uninterrupted power supply)
    Richard is right it will die sooner than it normally would if not used regularly.
  4.    06 Mar 2017 #4
    United Kingdom
    Local Time: 03:11
    england uk england
    Plugged in for sure. Better battery life span
battery plugged in, not charging
I am currently using a laptop that is approx one year old - it's a toshiba tecra A6. It belonged to a friend and I have only received it recently,...
Vista hardware & devices
Laptop on Battery even though it's plugged in
my best friends laptop won't charge atall she's plugged it to the wall and it wouldn't charge she's taken the battery out then put it back in with...
General Discussion
Plugged In, Not Charging Battery
I have HP NW8000 laptop running Vista Ultimate. I installed SP1 a few days ago. After the upgrade, the battery is not charging anymore. Right now it...
Battery plugged in, not charging
I'm running Windows Vista on a Gateway NX570X laptop. About a year after I bought it, it slid off the table and bent the connecter for the original...
Alter (auto) Power settings when plugged in or on Battery Power?
I'm running a laptop and would love for the power settings to automatically change from high performance when plugged in to Ballanced or Power Saver...
Vista performance & maintenance
Battery Icon is in system tray on plugged in Desktop using Vista U
I have an HP desktop which is always plugged in. In the system tray the Battery icon is active and for some reason Windows thinks it is on a laptop...
Vista General
Laptop battery issue ??battery calibration??
Thanks for reading this. i have never posted anything in my life but i am stumped:sarc: and need some help! I got a dell inspiron 2200 and one day...
General Discussion
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
