Laptop on battery or just plugged to electricity
I have a laptop I m using it like a desktop I was wondering should i use it without battery by electric only ?
here its link of my laptop if it helps
PS: I m using my laptop with europe plug since I live in europe I m using another plug to plug it plugger
richc46
I have read that it is best to let it run on battery now and then and recharge when 2/3 used. If you just keep it plugged in, actually no problem. The battery will just die sooner, but no matter to you, since you have it plugged in.
ilikefree
I did that with my last laptop and used the battery as a power supply if the power went off (uninterrupted power supply)
Richard is right it will die sooner than it normally would if not used regularly.
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
