Firstly Hi
Just started getting a msg after trying to open something from doing a google search saying.
stop running this script.
A script on this page is causing internet explorer to run slowly
If it continues to run,your computer may become unresponsive.
If i then put the adrress in manually i can go to the page no problem. i have checked disable script debugging and still get the msg
Its starting to do my head in now. HELP
Cheers
Cheers
