0x124 BSoD (with minidump)
jrobinson3k1
Hi all,
I'm getting a very irritating BSoD. I recently reformatted and reinstalled Vista x86 and have been getting random BSoDs that I didn't get before. It only happens when I'm playing games. Sometimes it's 5 minutes into the game, other times it takes an hour or more. Also, this could be a likely problem, but I recently bought a 2nd harddrive and set up both harddrives in a RAID 0 array. They are different sizes, however (160GB and 320GB), but I was farely certain that the size difference wouldn't be a big deal (knowing it should just treat the 320GB as 160GB). Can different brand/speed harddrives be a reason for hardware failure when setting them up in RAID? Here's my minidump.
Code:
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 00000000, Machine Check Exception
Arg2: 85def3f0, Address of the WHEA_ERROR_RECORD structure.
Arg3: b2000040, High order 32-bits of the MCi_STATUS value.
Arg4: 00000800, Low order 32-bits of the MCi_STATUS value.
BUGCHECK_STR:  0x124_GenuineIntel
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT
PROCESS_NAME:  Wow.exe
CURRENT_IRQL:  0
STACK_TEXT:
81930f38 818118b5 00000124 00000000 85def3f0 nt!KeBugCheckEx+0x1e
81930f8c 818fe928 85def3f0 8515b580 8515b580 hal!HalBugCheckSystem+0xe1
81930fb8 818117c9 8515b580 00000000 81930ff4 nt!WheaReportHwError+0x1d0
81930fc8 81811ea7 00000003 8515b580 00000000 hal!HalpReportMachineCheck+0x31
81930ff4 8180d99f 80154000 00000000 00000000 hal!HalpMcaExceptionHandler+0xf7
81930ff4 00000000 80154000 00000000 00000000 hal!HalpMcaExceptionHandlerWrapper+0x77
STACK_COMMAND:  kb
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: hardware
IMAGE_NAME:  hardware
DEBUG_FLR_IMAGE_TIMESTAMP:  0
FAILURE_BUCKET_ID:  0x124_GenuineIntel__UNKNOWN
Followup: MachineOwner
BTW, I've had numerous crashes, yet this is the first time it actually wrote a minidump file (yes, I've had it enabled the whole time). 1/2 the time the computer automatically restarts (no BSoD), and usually the rest of the time it says it writes the memory dump but it never does. So I'm lucky to of finally got something to hopefully pin-point my problem.
    Intel Core 2 Quad Q9450 @ 2.66GHz
    EVGA 123-YW-E175-A1 LGA 775 NVIDIA nForce 750i SLI FTW
    4GB (2 x 2GB) DDR2 800
    2x nVidia 8800GT 512MB
    HT Omega Stryker
    2x Acer X233Hbid Black 23" 5ms
    1920x1080
    2x 180GB in RAID 0
    500GB USB External HDD
    800W Antec
    1x 200mm, 4x80mm
    Logitech MX518
    ZBoard
    Cable
ambientmf
I don't think your RAID array is the problem, you'd probably be having trouble booting into Windows if there was a hardware failure with your drives.
I'm guessing an issue with your graphics drivers?
Have you updated to the latest versions?
Are you using a nvidia based card or ATI based card?
    Lenovo ThinkPad T61p
    Intel Core 2 Duo T8300 2.4GHz
    4GB Corsair 667MHz (PC2-5300)
    Nvidia Quadro FX 570M
    Seagate 7200rpm 160GB
    Logitech MX 518
H2SO4
A bit of a numpty
Well written problem description. Have some rep.
A stop 0x124 means the hardware has complained about something and Windows is passing along the message. The memory dump is devoid of pertinent info except for these two numbers, from your post:
They're bitmasks and between them they make a 64-bit binary number:
10110010 00000000 00000000 01000000 00000000 00000000 00001000 00000000
^ bit "63", the "most significant" bit. The zero on the right end is bit "0".
To understand what each of the 1s signifies in your instance, you might want to review chapter 14 of this Intel doc:
http://www.intel.com/Assets/PDF/manual/253668.pdf
jrobinson3k1
Thanks for the replies.
If you click the link at the bottom left of my post you can see my system specs. The only difference now is I am running Vista Business x86 (because I thought x64 could be the culprit). Though I still get the same problem with x86, they're not nearly as frequent as they were before (guaranteed to crash within 5 minutes with x64). I have 2x GeForce 8800 GT in SLI (with SLI enabled) and running the latest drivers.
I also recently bought a 2nd monitor, but am highly doubtful that would cause an internal hardware failure.
I had stumbled across that PDF before, it's a very good find. I was in the process of separating the bits last night to determine my problem, but it was late and I didn't get to finish. Was difficult having to go back and forth between different pages of the PDF to get the information I needed. :P
Also, everything is running stock (no overclocking).
    HT Omega Stryker
    1920x1080
    2x 180GB in RAID 0
    800W Antec
    1x 200mm, 4x80mm
    Logitech MX518
    ZBoard
    Cable
jrobinson3k1
OK, here's my analysis of the 64-bit MCi status
Code:
[COLOR=Olive]1[/COLOR][COLOR=Sienna]0[/COLOR][COLOR=Purple]1[/COLOR][COLOR=SlateGray]1[/COLOR][COLOR=Lime]0[/COLOR][COLOR=Cyan]0[/COLOR][COLOR=Pink]1[/COLOR][COLOR=SeaGreen]0 0[/COLOR][COLOR=Red]00[/COLOR][COLOR=Blue]00000 00000000 01000000[/COLOR] [COLOR=DarkOrange]00000000 00000000[/COLOR] [COLOR=Black]00001000 00000000[/COLOR]
VAL - [COLOR=Olive]1[/COLOR]
OVER - [COLOR=Sienna]0[/COLOR]
UC - [COLOR=Purple]1[/COLOR]
EN - [COLOR=SlateGray]1[/COLOR]
MISCV - [COLOR=Lime]0[/COLOR]
ADDRV - [COLOR=Cyan]0[/COLOR]
PCC - [COLOR=Pink]1[/COLOR]
Reserved - [COLOR=SeaGreen]00[/COLOR]
Threshold-based error status - [COLOR=Red]00[/COLOR]
Other Information - [COLOR=Blue]00000 00000000 01000000[/COLOR]
Model-specific Error Code - [COLOR=DarkOrange]00000000 00000000[/COLOR]
MCA Error Code - 00001000 00000000
I'm just going to type this up as I decipher it.
Looking at the MCA Error Code, I determine it's a compound error code. Looking at the types, it looks like 000F 1PPT RRRR IILL fits the bill of my error code. This is a Bus and Interconnect Error type.
Code:
0000 1000 0000 0000
000F 1PPT RRRR IILL
F is 0, so I have "normal" filtering.
LL is 00, which is a level 0 hierarchy level and mnemonic L0.
RRRR is 0000, which indicates a generic error with mnemoic ERR
PP is 00, local processor originated request, mnemoic SRC
T is 0, no time-out, mnemoic NOTIMEOUT
II is 00, memory access, mnemoic M
BUSL0_SRC_ERR_M_NOTIMEOUT_ERR
All right, so I have no idea what that means, but there it is. The PDF says to reference Appendix E, but it only appears to go to Chapter 17. Where's the rest of the PDF!?! Well if anyone knows these codes by hearts, please let me know if you can pick out any possible culprits! Thanks.
    HT Omega Stryker
    1920x1080
    2x 180GB in RAID 0
    800W Antec
    1x 200mm, 4x80mm
    Logitech MX518
    ZBoard
    Cable
stormy13
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Acer P221w and Acer 1916w
    1680x1050 and 1440x900
    Antec Earthwatts 500W
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
jrobinson3k1
Thanks, I'll try that out once I get off work and let you know if that works.
    HT Omega Stryker
    1920x1080
    2x 180GB in RAID 0
    800W Antec
    1x 200mm, 4x80mm
    Logitech MX518
    ZBoard
    Cable
jrobinson3k1
I flashed an update for the BIOS and no problems since then. Thanks for the help!
    HT Omega Stryker
    1920x1080
    2x 180GB in RAID 0
    800W Antec
    1x 200mm, 4x80mm
    Logitech MX518
    ZBoard
    Cable
jrobinson3k1
Nevermind, it's still doing it, though its rarer now for whatever reason. Only happens during WoW (hasn't crashed any other games in a while). Nothing in particular seems to trigger it. Any other suggestions are welcome.
    HT Omega Stryker
    1920x1080
    2x 180GB in RAID 0
    800W Antec
    1x 200mm, 4x80mm
    Logitech MX518
    ZBoard
    Cable
H2SO4
A bit of a numpty
jrobinson3k1
So I think I found the problem, and I'm not happy about it.
As mentioned in my first reply to this post, the only new hardware changes were a second HDD and a second monitor. Well, apparently SLI and dual-monitors don't mix. Since I've disabled SLI, no BSODs for 3 days! Needless to say, I'm upset I can't use SLI with my two monitors. But at least the problem is found (95% sure, since no BSODs since).
Thanks for all your help!
    HT Omega Stryker
    1920x1080
    2x 180GB in RAID 0
    800W Antec
    1x 200mm, 4x80mm
    Logitech MX518
    ZBoard
    Cable
