2 differing nvidia cards?
Im more interested in running 3 monitors than SLi. So, I have 2 differing nvidia cards here, a 7300gt and an 8400gs..
In theory they should work in the same system no? If I make the 8400 my main card and the 7300 my secondary card.
run 2 wide screens off the 8400 and an older 19" non wide off the 7300
should work right?:p
worked in xp I think. but get this..vista gave me a 4.3 for my 7300, and a 3.5 for my 8400..go finger..uhh..figure.. go figure.:confused:
.Joe
1337 spammer
Welcome to the forums!
I did some digging around and couldn't come up with anything solid about running three monitors. I did find a site that discusses multiple monitor usage. There may be some information there that would be helpful.
Here's the website: Multi-Monitor Resources at www.realtimesoft.com
I hope you are able to make the configuration work. Please let us know when you find a solution.
    Intel Q6600 Quad Core 2.4 Ghz
    Dell 0TP406
    Nvidia 8800 GT 512 MB
    Dual Dell 22" Widescreen
    3360x1050
    320 GB Internal Main
    500 GB USB External
    160 GB USB External
    2TB USB External
    DSL 3MB
03hdfatboy
Vista Pro
If I disable crossfire I can run up to 4 monitors at once so I have read.. but the most I've run was a 22"ws 20"ws an a 19" CRT.
I used to run duel monitors on a reg. basis but now I just run duel PC's and I like that better. :p
    RJ's Toyz/HOTROD
    DFI LanParty UT P45-T2RS
    G.SKILL 8GB (4 x 2GB)
    24" and 22" Acer LCDs
    1920 x 1200 / 1680 x 1050
    PC Power & Cooling 1200W
    Cooler Master HAF932
    Logitech G9 @28grams
    Logitech G15 Gamer
    very very very slow
    3DMARK06 = 23114
I run 2 monitors for my daw. Tracks on one and mixer on another. Im thinking of a 3rd monitor for my plugins. Theres some kind of bubble monitor thing that you sit in and the monitor kind of surrounds you...almost like omnimax.
z3r010
Staff member
I'm running 4 monitors, as long as you dont want SLi you will be fine with the different cards, its just plug and go ;)
  • Show second system?
    Yes
    Operating System
    Windows 10
    me
    Asus RAMPAGE V EXTREME
    Creative
    6 @ 2560x1440
    3x 1TB Samsung Evo 840's
    1500W ThermalTake Toughpower
    ThermalTake Level 10 GT
    Enermax Liqtech 240
    Logitech Performance MX
    Surface Ergonomic
    350 Mb/s
    WinTV NovaTD
    HP CP1515n Color Laser
    Microsoft LifeCam Cinema
    APC 750i Smart UPS
    windows 10
    Surface Pro 3
    Intel HD Graphics 4400
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
gazz496
a mere mortal
Vista Pro
i wonder if it's because he is running 2 identical cards that he doesn't get the same probelms with multiple moniters, kinda like aa driver conflict within the system (i don't know the technical term ) hope this is resolved as would like to clear it up so i can do it too
    me
    intel Q6600 @3.0Ghz
    gigabyte EP35C DS3R
    8 GB OCZ 1066 HPC REAPER
    Sapphire 4870 HD 1024mb gddr5
    lg flatron 20.1
    western digital 350gb
    samsung spinpoint 120gb
    900w
    thermaltake aguila
    2x 120mm 2x 10cm
03hdfatboy
Vista Pro
#8
Thanks peeps.
It worked.:D I'M going to redo my system, but it does work.
How are the new ATI drivers?
CRAP! :confused: I had to roll mine back. I kept loosing my signal to my monitor and it would also boot up @ 800x 600 every time and I run mine at 1680x1250 and it was not available :mad:
    RJ's Toyz/HOTROD
    Logitech G15 Gamer
    very very very slow
    3DMARK06 = 23114
