2 Layers Of Encryption?
PainlessTorture
Official Best Member
Vista Pro
I have full drive encryption (256-AES) from truecrypt. If i was to use BitLocker and encrypt my drive again, would I have two layers of encryption or would BitLocker overwrite my truecrypt encryption?
    Hewlett Packard
    3.40Ghz / 2.20Gz Duo Core
    2GB / 3GB
    160 GB / 160 GB
Chappy
Tech Help since 1993
Why the heck would you need too do that???
Are you the keeper of your country's most valuable secrets or something, or just a bit on the "Overly" careful side...;)
First off, you already have 256bit encryption so you would have to have something extra valuable for someone to try to break that level of protection, because it certainly would be nearly impossible to do already and I really can't see someone taking that time & effort for a basic User machine's data.
Now I'm not positive, but you very probably "could" corrupt it all by trying to encrypt data that's already been encrypted by another process, so I wouldn't even try this if I were you. If you're determined to try it tho, I would test it on some unimportant data first.
But seriously, it's almost impossible to break a 256bit encrypted drive in the 1st place. Since the encryption algorithm process is random and requires the key that's made during the encryption process to decrypt it, it's basicall y a brute force attack and that takes serious time. I think you'd notice it before they got anywhere near breaking thru.
    Personal Build
    Intel E6750 Core 2 Duo
    Asus Commando MoBo (P965/ICH8R)
    4G's Crucial Ballistix Tracer DDR2 PC26400 RAM
    BFG 8800GTS OC2 320MB
    Creative Sound Blaster X-FI Platinum FATAL1TY (next)
    2 x 22" w2207 LCD Monitors
    1- 1680 x 1050, 1 - 1920 x 1080
    3 x 500G SATA II WD Caviar HDD's
    EnerMax NoiseTaker II 600W
    NZXT Lexa Classic (modified, dual doored & windowed)
    Zalman 9700 CPU cooler, 4-120mm fans, 1-90mm
    Logitech Optical Trackman trackball
    NZXT Lexa Classic Case, Zalman 9700 CPU Cooler, 2 DVD Burners c/w LightScribe (Sony, TSST), Enermax NoiseTaker II 600W PSU with Custom Chrome cable sleeving, Hauppauge HDTV TV Tuner Card, 5.1 Logitech Z5500 speakers, 15 in 1 Multi-card reader
PainlessTorture
Vista Pro
I'm secretly the directer of MI6 and have nuclear launch codes on my machine...;)
Thanks for the reply :)
Btw, the codes to decrypt the computer are 37 characters long with upper and lower case letters, special characters and numbers and its all random :)
    Hewlett Packard
    2GB / 3GB
    160 GB / 160 GB
