2 Microsoft ACPI-Compliant Control Method Battery drivers
Hvrijssa
Hi all
I have an HP Elitebook 8440p and it started showing the famous 'Plugged in, not charging message'. Well, the solution for this problem seems to be quite a simple one: uninstalling the 'Microsoft ACPI-Compliant Control Method Battery' driver and let Windows reinstall the driver. However, my system has 2 'Microsoft ACPI-Compliant Control Method Battery' drivers installed and when I delete both and let windows reinstall it I end up again with 2 of them and the battery issue persists. How can I prevent Windows from installing it twice? Thanks.
Mooly
Just thinking aloud... and firstly this could well be a battery issue.
To remove the drivers have you tried removing the battery and then setting device manager to show hidden or unused drivers ? You could then try uninstalling them. Perhaps try the method in post #2 of the third link first.
https://windowsforum.com/threads/remove-old-device-drivers-hidden-in-vista-and-win7.41351/
http://www.vistax64.com/tutorials/163016-ghost-devices-drivers.html
http://www.vistax64.com/tutorials/80368-device-manager-hidden-devices.html
